DP5 & Rewire with Ableton live
Hello, i need some informations about that. i have tried to connect ableton live in rewire with dp5 but without success. i have read the manual that says to create a project in reason (or live i think;)) with a synth for examples, than save it, than open dp5, create an aux with for inputs the rewire buss of reason (or live) than open reason and load the project.
well.. i can't find the rewire buss..there isn't and live says that cannot run as a slave mode..
there is anyone that use live and dp5 in rewire? for me is essential because i need the simplicity of live and its powerful plug ins, and the simple editing and the delays track .. a lot of things.. and i need the great engine of dp5 because live with a lot of track is really digital sound..
thanks
bye
thanks
bye
- Mr_Clifford
i have do that..
"than open reason and load the project" or live..
i have used often the rewire.. i know first master than slave.. i think it's a simple thing.. but i can't do that in dp5..
for that i've ask that to someone that use dp5 and live in rewire, because i think there is something different.. some tricks specific for live..
i've also read to instal reason demo to have the rewire engine, i've do that.. nothing changes..
the problem is that i haven't got any rewire buss any rewire option to choose as input in the aux track
me too
i am having same problem didn't have this prob with dp 4
dp5.12 NOT ReWiring to any thing
I'm not getting any rewire input busses in DP5.12 either. niether reason nor Live outputs make them selves available to DP. Very iritating.
DP 5.11/2.16Ghz core duo 17" MacBookPro/presonus firePod
"DON'T BELIEVE EVERYTHING THAT YOU THINK" -buddha
- Dwetmaster
Make sure the There is an aux or an audio track with a valid output fed Reason's main out. Do you see reason output in the bundle/instrument tab?
Himattianlaseppia wrote:anyone.. can help me?
Download ReWire update here:
http://www.propellerheads.se/
Go to: Downloads > Miscellaneous updates > ReWire
I hope it helps.
jarok
LIVE works fine as a rewire slave in DP 5.12 for me.
DP 5.13 dual G5 2.7 synced to dual 1.42 via SMPTE, Muse Receptor (filled with Stylus RMX, Trilogy, Atmosphere, Elektrik piano, Disco DSP), OSX.410, Ableton LIVE, Apogee Big Ben, Apogee mini DAC, MachV, Symphonic, Ethno, M-Tron, Mx-4,Latigo, Jupiter Vi, iDrum, Microtonic, Kontakt3, Bassline, Bassline Pro, Ultra Focus, Novation Basstation, Novation Drum Station, Nord Lead2, JD-990, EMU Proteus, Orbit 2, MicroKorg, UAD, Poco, Altiverb, VW2, Waves, Ozone, to name a few
- thracks
DP can only be a Rewire "Master"fepagani wrote:revival of old threads....
Hi,
Can anyone confirm to me if is possible to get DP5 on rewire slave mode to Ableton Live 6?
please say YES....
and if so... how do I go on to do it?
You can only run Live as a rewire slave to DP. It's the same with Logic as well.
Steve
2020 Mac Mini | Sonoma | 828x |
