Adding More RAM for DP >???
tommypenngotti
Post by tommypenngotti »
Powerbook G4
1 Ghz
512 DDR RAM
If I up 512 more RAM am I going to notice DP running more smoothly? I would like to hear from some Powerbook DP users....
I just got 4.52 & noticed some of those Apple FX bog down my system a bit...
thanks :eek:
Mac Pro 4,1 2.66 GHz Quad Core, 16GB Ram, OSX.7.5, Dual Cinema Displays -ATI Radeon 5770, Motu 896/828MK II DP 8, Waves v9
tsd3000
Re: Adding More RAM for DP >???
Post by tsd3000 »
yes... do it. if you use samplers or instruments or lots of plugins for that matter. 512 is ok, but i just put in a 1G chip and it made things much better indeed!!!
Labonza
Post by Labonza »
You'll notice a nice performance increase when you double that RAM.
motuguy
Post by motuguy »
:eek:
Although I'm not a PBook owner it goes without saying that the more RAM the better the performance and stability.
Just run your "Actvity Monitor" ( go to Applications>>Utilities>>Activity Monitor ) to see the processing going on in the background while working with DigitalPeformer.
In addition it helps the economy.
QUICKSILVER G4 dual 1G process with 1.5 GB RAM
audiophile 2496 PCI card(MIDI/audio in/out)
running TIGER and PANTEHR
M-Audio USB MIDIsport 8 x 8 (MIDI interface)
8500/Sonnet G3 + USB and Firewire cards running PANTHER and OS 9
9500/Sonnet G4 + USB and Firewire cards running PANTHER and OS 9
tommypenngotti
any particular brand 512 DDR RAM I'm looking for? There is 512 RAM all over Ebay for $65,is there any difference between this & the $150 RAM @ apple store? I installed RAM in my old Dell laptop ..is it as easy in the Powerbook>? thanks
<small>[ June 11, 2005, 10:19 AM: Message edited by: tommypenngotti ]</small>
emulatorloo
Post by emulatorloo »
DO NOT BUY RAM OFF OF EBAY!!!! unless you really really know what you are doing. (maybe you do, I am not saying you don't)
Because> > >YOU DON"T KNOW WHERE IT HAS BEEN OR WHO HAS MISHANDLED IT!!!!!!> If you get bad ram because of this you will have nothing but Crashes Crashes Crashes.
Nor do you need to buy memory from Apple.
Here are two ram vendors I have used that are very good and have lifetime warranties on their ram. That means if it ever fails, they will replace it. That will not happen w ebay.
http://www.datamem.com -- click on "Apple/Mac Quick List" on the right hand of the home page. I have been buying RAM from them since at least 1994. about $65.00 for what you are looking for.
Other World Computing --- http://eshop.macsales.com/shop/memory/ Looks like 50.00 and up for what your looking for (I don't know your exact powerbook model)
I have been buying RAM from them since at least 2000.
Look in your powerbook manual for how to install the RAM. It is easy, but you have to follow the directions. If you don't have a powerbook manual, Download it at Apple here:
http://www.apple.com/support/manuals/powerbook/
I do not work for either of these companies. Best of luck with your upgraded powerbook!
<small>[ June 11, 2005, 11:21 AM: Message edited by: emulatorloo ]</small>
tommypenngotti
thanks 4 the advice, I agree.... ;)
geez ...my next question is should I just max it out to 2 GB ? anyone running 1.5 gig or 2GB?
<small>[ June 11, 2005, 11:40 AM: Message edited by: tommypenngotti ]</small>
rainmaker
Post by rainmaker »
I would highly recommend www.crucial.com. They match up ram specifically to your computer model and guarantee that it will work with your model. They also guarantee the ram for life. If you ever have any issues with it, they will replace it for free. Their prices are very good as well.
chrispick
Post by chrispick »
If you intend to run VIs with DP, then I'd say make the jump to 2GB (samples take up space fast). If not, try upping to 1GB and do some work with it. If that seems adequate, you're cool.
I like Kingston RAM; always use it. It's a good cost-to-quality-ratio purchase. I freelance as a 3D animator in Hollywood and nearly every prod house I go to uses it.
Studio615
Post by Studio615 »
I bought ram from otherworld computing from EBAY, if you look and find a reputable dealer you can find deals there. Don't bid on something, find the buy it now deals from REPUTABLE dealers. They usually have deals though on ebay that are cheaper than their own sites. IF you find the same spec ram you can buy it a local pc shop, it is the same thing. But as the other guy said, be careful. Max out your powerbook. It will pay for itself in about 15 minutes, the frustrations of the beachball will go away quickly, you will see it less. And turn off auto beat detect. I went from wanting to return my powerbokk because it seemed unusable fo DP to having a fast, smokin' portable daw by turning this "feature" off. My specs are: 1.67ghz, 1.5 mb ram. Really makes a difference. Good luck.
Powerbook G4 1.67ghz (15"), 828mkII, rockit 8 monitors, and lots of coffee on those long late night sessions.
