MOTU 828mkII USB Suttering, Clicks, Pops -any advice?
chetubetcha
Post by chetubetcha »
Hi Everyone,
First post and I'm asking for help , apologies. Just bought a shiny new 828mkII usb for my PC and I'm buggered if I can get it to work properly.
For various reasons I'm stuck using a PC and Adobe Audition 2.
On recording I'm getting drop outs and stutters, on playback I'm getting delays and crackles etc...I have tried everything I can think of, uninstalling pretty much everything but the 828 drivers, thge machine is well spec'd, all services not required are off, flattened the machine and started fresh...it's a dedicated machine with enough muscle and still I'm struggling.
I'm wondering if it is this XP SP2 problem, if it is I'm ruined as Audition needs SP2 to run...before I take this card back to the shop, could anyone suggest what I might be doing wrong?
Any help would be much appreciated.
Adobe Audition 2
2 x 500GB Samsung SATA II 300 Hard Disk Drive 16MB cache 7200rpm oem @ configured in RAID 1
1 x Gigabyte GA-965P-DS3 SKT 775 P965 Chipset PCI-E, DDR2, SATA2 GB LAN, 8ch Audio, USB2, ATX
Trust Firewire PCI Card VI-2050 .
Sapphire Radeon X1650PRO 512MB DDR2, PCI-E, Dual DVI, VIVO,
Microsoft Windows XP Home (oem) inc SP 2b (
ntel CPU Core2Duo E4500 2x2GHz 800FSB LGA775 2MB cache Retail
80GB Maxtor DiamondMax Plus20 Hard Disk Drive ATA100 7200rpm .
Kingston 1GB Value Ram DDR2 667MHz PC5300 Memory @
polive
Post by polive »
I too am suddenly experiencing Noise out of the blue! I have no idea why this has started and I'm very alarmed. Sorry I can't help, but I'm hoping MOTU will look into this since this is clearly not a one-off!
splatterbass
Post by splatterbass »
decent setup on the rig.
have you tried the samples per buffer settings?
i have to have mine set at 512.
if nothing happens there, then pm me i have the sp 1 roll back in a zip file.
i can fire it off to you.
chetubetcha
Thanks for the reply, very much appreciated .
What exactly does the service pack roll back , roll back?
splatterbass
it`s all the setting for the 1394 port and "language" that windows uses to "talk" to the fire wire port.
as well as how to access the port on the bus.
windows does not do any "direct" hardware calls, unlike linux or older mac ( pre intel chips ) it "talks" to the hardware through drivers ( translators, have you ever looked at a dll tree? translators for translators. )
to make a long story short, it uses an older language that works. lol.
before microsoft decided to change the dialect.
thehowler
Post by thehowler »
Same problem here with similar spec. PC.
Did anyone get this fixed?
chetubetcha
This is seems was directly linked to USB problems. I was using a USB keybord and mouse which when I unplugged it fixed the problem. Using a standard PS2 mouse and KB and all is well now...
doesn't really solve the issue, it is clearly an issue with USB interrupts configured on my machine.
