Ultimate Widget :)
Ultimate Widget :)
The MUST HAVE widget of all time for the Mac:
http://www.apple.com/downloads/dashboar ... looch.html
Excellent!!!
Excellent!!!
I've never even opened a widget, Magilla.
Somehow, disabling them in the name of DP-smoothness prudence has won out every time.
Now, you've got me thinking and tempted.
Yup, methinks I'll try this one; thank you!
Super relaxing. As far as disabling the widgets, I needed to do that in Panther, but Tiger doesn't seem to mind. All totaled, my widgets take up 4-7% of my processor. Not going to make a big difference.
Re: Ultimate Widget :)
On your recommendation, this will be my first widget! it looks cool. Like monkey, I always shied away for fear of cpu drainage.MIDI Life Crisis wrote:The MUST HAVE widget of all time for the Mac:
Excellent!!!
Macbook pro, 3 gigs of ram, osx 10.62, Dp 5.13, Live 8.1.2, Reason 4, Tc powercore Virus, Albino 3.02, proper ergonomic sitting posture, plenty of coffee (french press only with a pinch of cardamon added)
My dp inspired music.....
http://www.myspace.com/aislingbeing" onclick="window.open(this.href);return false;
http://www.myspace.com/wigginsmaroo" onclick="window.open(this.href);return false;
http://www.mp3.com.au/artist.asp?id=10004" onclick="window.open(this.href);return false;
Josh, it's not just CPU; apparently widgets use a lot of RAM and virtual RAM.
Can't zip the file or a folder containing the file for some reason.
Crashes the Finder every time.
is it using ram regardless of the amount of widgets or does the amount of ram go up upon more widgets? will dp 6 fix thismonkey man wrote:Josh, it's not just CPU; apparently widgets use a lot of RAM and virtual RAM.
After 20 minutes I'll say it's not bad. I actually prefer the "old school" way I do it by turning on my electric tambura, as well as desk top water fountain and consuming 300% more electricity!
Don't know, Josh.
I read somewhere that hundreds of MBs are used though.
I've always used the following Terminal instructions or a little app (which I can't now find - must have been PPC):
To turn Dashboard off:
# defaults write com.apple.dashboard mcx-disabled -boolean YES
To turn Dashboard on:?# defaults write com.apple.dashboard mcx-disabled -boolean NO
You have to restart the Dock after making either change for it to take effect:?# killall Dock
thank you!monkey man wrote:Don't know, Josh.
I never liked the idea of dashboard not having an "on/off" button!
While I was being sarcastic. It would almost be cool if DP 6 had an "optimize your system for DAW" utility app that could do such things as turn off dash, and other cpu draining events on command from dp........am I reaching here?
Hey, why not?jgest wrote:... am I reaching here?
You'd think, provided it worked, that almost all users would appreciate having the guesswork taken out of performance tweaking.
Sorry I missed your previous post.
Please try the commands and see if they work for you.
I used to keep them handy as a text file in the dock for cutting and pasting.
They've been turned off for so long now, I'd forgotten they existed.
I tend to turn 'em off after major OS upgrades, and that's it.
