Using an older MIDI timepiece
djmikeybee
Post by djmikeybee »
I am trying to hook an older MIDI timepiece av up to my mac pro. Problem is it is not the miditimepiece av usb. Can i hook this up using another cable or is this just a boat anchor to me?
bkshepard
Post by bkshepard »
Time to drop anchor, mate. Unless you've got a serial card in your computer, the old MTP-AV won't connect. Sorry.
-Brian
djmikeybee
would this work
what about if i get a usb to serial(rs422) adapter. Would that work?
scott.gehman
Re: would this work
Post by scott.gehman »
djmikeybee wrote:what about if i get a usb to serial(rs422) adapter. Would that work?
No. There are timing issues that these devices can't handle.
If you buy a USB MIDI Timepiece you can network your old MTP.
jcmetz57
Post by jcmetz57 »
Hello!
I am newbie on this forum.
Does somebody use a Geethree Stealth Serial Port on a G5 with OS 10.4 with a MIDI Timepiece AV serial ?
Is it possible ?
Thanks.
JC
panduri
Post by panduri »
jcmetz57 wrote:Hello!
Is it possible ?
Thanks.
JC
Interested in this also. G5 or G4.
jcmetz57
Post by jcmetz57 »
Up.
Please.
bkshepard
Post by bkshepard »
There was a lot of discussion about this back a number years ago when the Macintosh switched from serial to USB. I may be mistaken, but I don't remember anyone coming up with a successful solution. They could get the emulators to work with some devices, but as I recall, they wouldn't work with MIDI. Sorry I couldn't be of more help. I don't know if the archive for UnicorNation goes back that far, but you might do a Google search on that subject and look in the vicinity of 2001-2003. I think that was when most people were struggling with that issue. Good luck.
-Brian
Off the topic a bit but there's a guy here in San Diego who tries to post his SERIAL MTP/AV on the local craigslist every 2 weeks or so for $395, hoping somebody isn't informed.
bkshepard
Post by bkshepard »
James Steele wrote:Off the topic a bit but there's a guy here in San Diego who tries to post his SERIAL MTP/AV on the local craigslist every 2 weeks or so for $395, hoping somebody isn't informed.
Hey, maybe I should try that. I've still got my old serial MTP-AV sitting out in the garage. :wink:
-Brian
azusa749a
Post by azusa749a »
Is it possible ?
Thanks.
JC
I believe the last driver ends at 10.3. Same thing happened to my Keyspan USB adapter too.
miket
Post by miket »
About G4 and Stealth Serial Port
I have a G4 1,4Ghz Sonnet card (originally G4/450) running Mac OS X 10.4.9 and a Stealth Serial Port with 2 MTP II.
I have NEVER had any kind of problems. Stealt Serial Port is equally good and reliable with OS9 and OSX.
And with DP 5.1 all MIDI instruments are perfectly driven.
I've only encountered several problems with SoundQuest MIDI Quest 10XL...
But it's not Stealth Serial Port's fault.
The big problem is that now Stealth Serial Port is not anymore avaliable for G4 but only for G5 machines...
It's a sad new
Life without music would be a mistake
MacPro 10core i9 10850K MacBookPro 16" i9 DP11 2 16A 2 828mk3 2 8PRE Ultralite mk5 3 MidiExpress 128
jcmetz57
Post by jcmetz57 »
Hello.
Many thanks for your answers.
M. Miket, you say you have a G4 running Mac OS 10.4.9. But, which is the software which controls the MTP II ? It is the problem with the MTP AV. Do the last USB MIDI OSX Drivers and ClockWorks are compatible with a MTP AV serial through a Geetree Stealth ?
I've still got my old serial MTP-AV sitting out in the garage too :cry:
jcmetz57
Post by jcmetz57 »
Hello.
I asked to Geethree a question about compatibility for a G5 with a stealth card and a MTP AV serial interface.
Here is the response :
Hello,
If you G5 can support an internal modem card, then we have a Stealth card
that should work. You will need to use our Serial MIDI plug-in, not the USB
driver that MOTU provides.
Best Regards,
GeeThree Customer Service
sustainiac
Post by sustainiac »
Sell it to a windows XP user - MOTU has the WinXP Parallel port drivers for the MTPAV.
