424e and 2408 not working...
timothyclee
Post by timothyclee »
Hey all I need some help!! I've upgraded to a MacPro quad 3.0 with 2gig ram and installed the latest 424 drivers from the webiste on 9/11 and the 424e card will not recognize my original 2408. Is there some trick?? I've got the 424e installed in the 2nd slot and the PCI Audio setup utlility recognizes the 424e, but says no audiowire ports are being used. I've tried all 4 audio ports and all the open pci slots. Help!!!
Tim
http://www.timothyclee.com
MacbookPro-MacPro-Mico Express-DP 7.02
896HD x 2
8pre x 3
UAD Neve Bundle
SSL SSL Bundle
Kontakt 3
Ozone 4
caffiend
Post by caffiend »
Have you tried changing audiowire ports followed by a "refresh" in the PCI audio console?
I'm not using the same hardware as you are....but that has cleared up some similar problems for me.
moqtev
Post by moqtev »
Hey Tim!
Have you seen this thread?
http://www.motunation.com/forum/viewtopic.php?t=23251
I don't know but it might be helpful. Seems that it makes a difference if you install the drivers BEFORE the actual PCI card.
Morten
