kgdrum wrote:hey Frodo- I want to thank you for all of the kind support and feedback you have given everyone,sometimes a break gives you a perspective you would not have otherwise.
I suspect a bad MB or something along those lines..................... I might be off base with this ,but it seems to me your problems escalated with Fab4/Play.have you ever tried taking it out of your system ? I am curious if this is related in any way...... playing music without the technology(the immediacy) is nice ,it makes us create in different ways.
Enjoy the non tech serenity for a while and recharge,
I hope you get this all sorted out
KG
Thanks, KG. You're not short-stopping yourself! From what I've been reading to get around Apple Care thoroughly, it seems that I could expect to be without my MacPro for a month or so.
Yeah-- I'd spent a quite a bit of time with no plugins at all. It was just DP and OSX runnning on built in. I'd even taken out all peripherals.
But I have to also agree with Phil. There's so much going on with OSX as it and things like QT continue to go through considerable tampering (or updates, which ever is the more appropriate term). I've found a few threads on other forums where people started having kernel panics after going to 10.4.10. Some of the stories were downright nightmarish.
But, Fab Four works comparatively well in other DAWs, including Logic. There are little quirks that we know EW has to address, but only DP falls horendously apart with it as it does with some other plugins. I think Fab Four was the one zit on top of everything else. Its flaws were more glaring, but removing it took care of only one set of problems.
This fight ain't over yet!
