any success with Pluggo/DP512/intel ?
- daniel.sneed
My Pluggo AU Component (UB, v3.6.1) is in /Library/Audio/Plug-ins/Components folder
My pluggo plugs (free) are in /Library/Audio/Plug-ins/VST/Pluggo folder
None appear in DP
Any thoughts ?
None appear in DP
Any thoughts ?
dAn Shakin' all over!
- tremolounge
- daniel.sneed
Thanks Tremolounge, but yes, it's been done, for shure.
I have an I-Mac Intel and yes Pluggo is working.
http://www.spoonwood.net
http://www.davidgennaro.com
2.16 Intel Core 2 Duo, 10.4.11, 3gigs ram, Ultralite 2 (good Box),Bunch of FireWire Drives, guitars guitars guitars, plugins plugins , mostly use Kontakt3
- daniel.sneed
Please dogBoy, can you confirm the location of your Pluggo component ?
and the location of your pluggo plugins ?
Any thoughts of whatever could cause misfunction much appreciated.
daniel,
It sounds as if everything (component/VST'z) is in the right place.
You wrote "My pluggo plugs (free)" , are the free plugins UB compatible ?
Is Pluggo authorized ?
Maybe re-install Pluggo.
Like tremolounge wrote , you must run the "AudioUnit Scan.app" that comes with PLuggo. You'll know if it scanned because a lot of your component icons will have changed to the PLuggo icon.
You could follow this path: Library/Preferences/Digital Performer(tm)
and pull out the "Audio Unit Info Cache" (don't trash it, just in case of ...)
Let DP run and re-recognize your AUs, see if PLuggo shows up.
- daniel.sneed
Thanks dogBoy.
I've been thru all of your routines.
Think I'm on to something.
BTW my Pluggo Component is PluggoRuntime361.
My only puggo-based (synthéV4-Aks-Ems) VI shows up now in DP VI list.
But none of my pluggo fx plugins.
Any thoughts ?
Any thoughts ?
My PluggoRuntime is 361 also.
Glad you've gotten a synth to show.
Don't know about the fx plugins.
good luck
D
I enjoyed listening to AdOK
good luck
D
