any success with Pluggo/DP512/intel ?
daniel.sneed
Post by daniel.sneed »
My Pluggo AU Component (UB, v3.6.1) is in /Library/Audio/Plug-ins/Components folder
My pluggo plugs (free) are in /Library/Audio/Plug-ins/VST/Pluggo folder
None appear in DP
Any thoughts ?
tremolounge
Post by tremolounge »
You probably need to run AudioUnit Scan.app (in your Applications folder) -- unless you did that already(?). It hooks up the Pluggo AU with all your pluggo VSTs. You also need to run it whenever you add new Pluggo VSTs.
Mac Pro 2.66 | 8GB | X.4.11 | 828mk2 | UAD-1 + 2 | Logic 8 | DP 6
daniel.sneed
Thanks Tremolounge, but yes, it's been done, for shure.
dogBoy
Post by dogBoy »
I have an I-Mac Intel and yes Pluggo is working.
http://www.spoonwood.net
http://www.davidgennaro.com
2.16 Intel Core 2 Duo, 10.4.11, 3gigs ram, Ultralite 2 (good Box),Bunch of FireWire Drives, guitars guitars guitars, plugins plugins , mostly use Kontakt3
daniel.sneed
Please dogBoy, can you confirm the location of your Pluggo component ?
and the location of your pluggo plugins ?
Any thoughts of whatever could cause misfunction much appreciated.
dogBoy
Post by dogBoy »
daniel,
It sounds as if everything (component/VST'z) is in the right place.
You wrote "My pluggo plugs (free)" , are the free plugins UB compatible ?
Is Pluggo authorized ?
Maybe re-install Pluggo.
Like tremolounge wrote , you must run the "AudioUnit Scan.app" that comes with PLuggo. You'll know if it scanned because a lot of your component icons will have changed to the PLuggo icon.
You could follow this path: Library/Preferences/Digital Performer(tm)
and pull out the "Audio Unit Info Cache" (don't trash it, just in case of ...)
Let DP run and re-recognize your AUs, see if PLuggo shows up.
daniel.sneed
Thanks dogBoy.
I've been thru all of your routines.
Think I'm on to something.
BTW my Pluggo Component is PluggoRuntime361.
My only puggo-based (synthéV4-Aks-Ems) VI shows up now in DP VI list.
But none of my pluggo fx plugins.
Any thoughts ?
dogBoy
Post by dogBoy »
My PluggoRuntime is 361 also.
Glad you've gotten a synth to show.
Don't know about the fx plugins.
good luck
D
I enjoyed listening to AdOK
