MachFive 2 AU Not Showing Up In Logic
Just got hold of M52 - installed OK; updated iLok OK; Copied all DVD libraries OK; downloaded and installed 2.01 OK.
BUT the AU plug-in refuses to show up in Logic Pro v7.2.3. I've rebooted, trashed prefs, repaired permission but still no-show.
M52 runs fine in standalone and on an instrument track in Pro Tools LE. The plug-in is in the correct folder (library/audio/plugins/components) but Logic doesn't even register it at all. Logic's AU Manager doesn't find it. Any ideas? Thanks in advance!
- ttauri
I had this problem the day I installed it--wasn't showing up in any AU hosts--but couldn't tell you how I solved it--did nothing other than the things you mentioned, which didn't seem to work. But then next day, I booted up and there it was. <baffled>
Yours showing up in any other AU hosts, if you have any?
Peece,
T. Tauri
Peece,
T. Tauri
Do you have the update to 2.01 ?
Does it start up in stand alone mode ?
Don't use Logic. Just a couple of ideas....
/B
/B
