MachFive 2 AU Not Showing Up In Logic
maxpatch
Post by maxpatch »
Just got hold of M52 - installed OK; updated iLok OK; Copied all DVD libraries OK; downloaded and installed 2.01 OK.
BUT the AU plug-in refuses to show up in Logic Pro v7.2.3. I've rebooted, trashed prefs, repaired permission but still no-show.
M52 runs fine in standalone and on an instrument track in Pro Tools LE. The plug-in is in the correct folder (library/audio/plugins/components) but Logic doesn't even register it at all. Logic's AU Manager doesn't find it. Any ideas? Thanks in advance!
ttauri
Post by ttauri »
I had this problem the day I installed it--wasn't showing up in any AU hosts--but couldn't tell you how I solved it--did nothing other than the things you mentioned, which didn't seem to work. But then next day, I booted up and there it was. <baffled>
Yours showing up in any other AU hosts, if you have any?
Peece,
T. Tauri
bjornln
Post by bjornln »
Do you have the update to 2.01 ?
Does it start up in stand alone mode ?
Don't use Logic. Just a couple of ideas....
/B
Frodo
Post by Frodo »
Have you run the Project Manager to rescan AU's?
maxpatch
Post by maxpatch »
Thanks for input so far!
Yes - I have 2.01;
Yes -it works standalone;
No - I don't have any other AU hosts
Yes - I have rescanned AUs a couple of times after rebooting
Yours, still puzzled!
dougieb
Post by dougieb »
maxpatch wrote:Thanks for input so far!
Yes - I have 2.01;
Did you try manually checking it in the AU manager?
maxpatch
Post by maxpatch »
Hmm... How do you do that? I've run Start Logic AU Manger from Logic's preferences menu but MachFive 2 doesn't show up in the list - even as a failed AU. Since starting this post I've also reinstalled M52 but to no avail.
Thanks for your continued suggestions.
Max
maxpatch
Post by maxpatch »
Very peculiar (but happy) update to the problem...! I booted up Logic today and, lo & behold, there it was - M52 now working perfectly in Logic. No, I don't understand it as I haven't done anything else to my system. All's well that ends inexplicably well.
ttauri
Post by ttauri »
Strange, huh?
Peece,
T. Tauri
