Share tracks between projects?
am looking to recover some lost work from an old version of a project I am working on. I currently in the old version have two tracks that I would like to transfer their data over to the new version of the song, and I do not know if this is possible. I would rather not have to just bounce the information down to stereo tracks, as i feel that would impair my ability to adjust the settings, or keep the feel. Is there any help out there for me?
could you be any more vague? Please give more details!!!!
3GHz 8 core, 6GB ram, DP 5.13, OSX.4.11, PTLE 7.4.2, Rosetta 200 digi003, waves platinum, mach five, distressors, ADL 1000, API, Calrec, UA mic pres, neumann, AT, shure, Sennheiser and rode mics...old guitars and drums...nord rack 2, s90, micro korg...yaddda yadda.
http://myspace.com/monkeydenrecording
- twistedtom
It could be you want to save as a clipping and bring it into the new project as aclipping.
- Pappy725
Couldn't you just go to the folder where the audiio tracks are and drag them into the new project? Seems like that would work.
Stephen
Stephen
MacBook Pro (Retina, 15-inch, Early 2013)
2.4 GHz Intel Core i7, 8GB RAM, OS High Sierra 10.13.2, DP8.07, 256GB SSD
828mkII, 8Pre, Alesis M1 Active Mk2, Ext. FW drives, Yamaha fretless bass, Kay upright bass, Wechter acoustic/electric, trombone, baritone and a proclivity for polka music. (With sufficient quantities of beer) and I play country music.
- rockitcity
Re: Share tracks between projects?
Well, maybe not as simple as it may appear...crumps wrote:am looking to recover some lost work from an old version of a project I am working on. I currently in the old version have two tracks that I would like to transfer their data over to the new version of the song, and I do not know if this is possible. I would rather not have to just bounce the information down to stereo tracks, as i feel that would impair my ability to adjust the settings, or keep the feel. Is there any help out there for me?
If there are a lot of edits in the tracks and you want to keep the original info for any later tweaking, then twistedtom has the answer; save the tracks as a clipping and import the clipping to the new project.
If you are done with your edits on the two tracks, then do a bounce (or re-record to a new set of tracks) and import the bounced tracks into the new project. Bouncing the tracks will not affect the "feel" of the track. Bounce them without effects if you want to keep them clean for processing in the new project.
Either way, not too hard.
Bob
Mac Mini Quad i7 2.6 Ghz, 16 G RAM, 2 SSD's. Motu 896 HD Hybrid, 8pre, Fastlane USB, Presonus Faderport, vintage guitars!
clippings will probably crash - at least mine do on on my old g5 my macpro and the imac I borrowed... and my g3 from way back when - clippings are great for fx presets and "channel strips" tho...
best way is really really simple!!!
open old prject - note tempo - select the bits to want - everything? select all.... now copy....
close project..
open new project...
tempo the same?
set insertion point to first track and correct time...
press paste....
all will be pasted.... ofcourse you will have to have enough tracks to paste into - ( use show clipboard if u can't remember...)
and get this - even soundbite gain is brought across - ( which if you used load sequence would have been lost... )
now use save as and duplicate audio to avoid problems later....
close project..
open new project...
tempo the same?
press paste....
http://www.fork-media.com
- twistedtom
Good point Zaster I think we all thought this was not working for crumps.
Ok crumps you did try this first?
