bringing 2 mono files into 1 stereo track.?
how can I bring 2 mono files into 1 stereo track? is there an easy way to do this rather than rerecording a new file?
Re: bringing 2 mono files into 1 stereo track.?
Rename them in the Finder. New_name.L (and) New_name.Rn8tron wrote:how can I bring 2 mono files into 1 stereo track? is there an easy way to do this rather than rerecording a new file?
"New_name" being the ...duh!... new name.
What type of files are your mono tracks? (wav? MP3? aiff?)
Digital Performer wants to see Sound Designer II files in order to combine 2 monos into a stereo. Here's how I do it . . .
A friend sends me some dubs of a stereo electric guitar pass (usually mailed to me on CDR. (Sometimes emailed as MP3's, but most of the time on CD as 2 mono wav files. I open the song document into which I want to import, drag the 2 mono files directly from his CDR into the soundbites window. DP converts the wav's into SD II files, although they'll still show as 2 mono files.
Now, I go to the Finder and locate these new files in the Audio Files folder of the song I'm importing into. I make sure they're named "guitar.L" and "guitar.R", then shift/select both files at once and drag them directly from the Finder window onto an open stereo track in the sequence editor (or tracks overview window, if you desire). Voila! A stereo track! Works every time.
Hope this helps.
AB
Hope this helps.
AB
- Appalachian Boy
Also, route them both to an AUX track and process the aux track.Appalachian Boy wrote:go to audio files in your project folder, they are sdII there, if not i dont know waht to say,
you could bus the left track to bus 1 and the right to bus 2, then record on a stereo track with an input of bus1-2. then you would have a stereo file.
