what am i doing wrong..
i have a great sounding drum track in Reason, i export as a song(aiff 48/24), and when i drag into Dp the track loses all punch and clarity..
Hey i use reason all the time and it's mix engine to my ears is not the best so rewire it to DP and IT SOUNDS a lot better because it uses DP mix engine and you can use DP and other plugs,
Best
Kassonica
I never use reason this way. It could be that you are using reason's mastering combinator and that is not getting included in the bounce (?) Try recording the main outs of Reason straight into DP via rewire and see if that makes a difference.
If you enable MultiRecord for audio tracks in DP preferences.
You can assign many Reason outputs to desired tracks in DP when using ReWire.
I do this all the time. If you want the drums to sound exactly as they do in Reason use Reason 1/2 in the audio output as the mixer is plugged in to the audio out for Rewire. This will incorporate the Aux inserts in Reason's Mixer. I like my tracks dry as my plugs in DP are much better. Be sure to understand that sometimes mono tracks are better for some sounds and that each inst. in Reason has a R&L output. I use the left when I want mono.
iMac 2.7Ghz quadcore i5 16 gig RAM DP 7.24 OS 10.6.8, iMac G5 2.1GHz 2.5 gig Ram DP 5.13 OS 10.4.11 MOTU 828 MK2, East West Platinum Plus, Miroslav Philharmonic, Komplete 5, Kontakt 2 Garritan Big Band, Mr Sax T, The Trumpet, DrumCore, Trilogy and Trillian, Ivory, MachFive, Ethno Instrument, Reason 4, SampleTank 2 Sampletron, Samplemoog, Melodyne Editor, Nomad plugins, Vintage Warmer, Ozone 4, Amplitube Jimi, Xgear and AmpegSVX.
http:www.davidosuna.com
