I've considered running Kontakt2 in standalone mode and seeing how the computer responds to that setup but honestly, at the moment, I don't feel any pinch that makes it necessary to try that...and it's always a pain to be saving multiple apps in a single computer for one song....if I can do what I need to all inside DP, then I'll go that direction and not worry that I'm not slamming the computer as hard as I can. If I run out of power, then I'll consider other ways to work in the box, but that doesn;t seem likely at the moment.
And I'll mention this again.....the Altiverb test may not have had any direct real-world signifcance, but it did demonstrate one thing------it IS possible for DP to recognize all the power in the 8 cores. Whether it can actually use it in an intelligent way is another story.......
By the way, I'm running into a problem where I can't drag a MIDI clipping onto the tracks window on the 8core.....it crashes dp 100% of the time. Even with a simple session with only one MIDI track, it crashes every time. I'm at the NAB show right now and MOTU has a booth here....I talked to one of the tech guys, but he had not heard of this issue.
And my multiple-MIDI-devices-showing-up-in-dp's-device-list issue is back. When I go to select a MIDI device in dp, I see two listings of every device created in Audio MIDI setup......the solution is to make the setup again.....argh...what a pain.....I think I need to make a backup of a healthy AudioMidi Setup and see if that can help as a workaround....and my hard drives continue to mysteriously go invisible.....ah the price of progess.....
The Digi guys are getting closer with their new sampler.....an interesting note about their sampler.....it's only RTAS.....meaning, even if you have a massive PT HD rig, you'll still be running this sampler as a native plugin....hmmmmm.....They were saying it has 512 note polyphony and "works with Giga patches"...when I asked if that was 512 stereo or mono notes, the person did not know. They said there's a public beta of it.
Apple's booth is huuuuuuuuge and it's buzzing....Final Cut Studio 2 has everyone running around giddy...
The new versions really do look nice...so many awesome things in that bundle....Adobe is also buzzing with CS3.....there's lots of excitement at this show....lots of new stuff to see.
Now I see why Apple put out these 8cores and started shipping them so fast.....they wanted to have them at this show to show off all the cool new stuff!
Cheers.
-gabe
