Moving V-Rack channels back to the sequence ?
thereaktor
Post by thereaktor »
Is their a way to move V-Rack channels back to the sequence?
thanx
Dwetmaster
Post by Dwetmaster »
:shock:
I nerver thought about this. I would use a clipping for the FX and create a new track in my sequence.
thereaktor
Thanx,
That is what I was thinking to do.
I'm just doing my first mix with DP and I found that nice to organize all Fx in one V-Rack, all Auxes and Master in another. But then I realised that I can't automate the V-Racks. So an elegant way to put the V-Rack in a sequence would have been welcomed.
Cheers
Post by Shooshie »
Output the V-racks to Auxes and automate the Auxes. There is no need to automate V-racks. Unless the V-Rack instrument will always be panned and levelled exactly the same, there is no need to adjust it in any way. Just use the Auxes for that.
If you really want to put your V-Rack back in the sequence, you might try just dragging its chunk over to your Tracks Overview Window. If the window highlights, then it will probably work. Since it contains no data, it might not work. If it does work, it will install a set of instruments into your Sequence as copies of those in the V-Rack. I've never tried that, but dragging chunks into your sequence is a viable way of quickly combining things.
thereaktor
I have some Fx on my aux tracks that I want to automate plus level and pan.
So I'll try your drag and drop trick when I go back in the studio.
We have "move selected track to V-Rack" so I was hoping their was a reverse function "move selected V-Rack track to sequence"
cheers
Tim
Post by Tim »
It does work, but the MIDI tracks that were addressing the v-rack instruments may need to be re-assigned to the ones that are now in the TO (I'm not sure though).....and then disable or delete the duplicated v-rack.
Great thinking, Shoosh.
I scratched my head over this one last year and only had a rash to show for it.
