error reading from disk,file not loaded -43
ozheri
Post by ozheri »
so i got my new KRK V4 today and was excited to do some mixing..
opened a project in DP exported a few files, for outside editing, imported files, save projest then opened and closed 3 or 4 more times....then when i went back to open the project for the 5th time in DP i got the above error code..i cannot open any of the mixes of the specific project, all are in the same folder.
i also cannot open any instances on my backup drive i get the same error code.
i rpaired permissions, restarted,did and onyx clean to no avail..
sometimes i wish Frodo and Shooshie lived next door...
help please!
powerbook G4 1ghz /1ghz RAM
tiger 10.4.10/DP 5.12
motu 828(oldie)
REASON,MELODYNE
ozheri
i tried..
Post by ozheri »
...loading chunks but it only loaded some of the soundbites..
while smoking on my balcony i was imagining all the unicorns living in an apartment complex ala melrose place, i then thought of glancing across the courtyard and seeing James Steele in his Easter bunny costume....ahhh what a beautiful daydream..
:lol:
motu 828(oldie)
REASON,MELODYNE
MegaDPuser
Post by MegaDPuser »
I have some potentially bad news for you on this one. About a month ago, I got the exact same error code and message. I had been working on the file for months. One night I saved the file, everything was fine, I went to bed, and the next morning I got that error. No idea why it did that; the only thing I had been doing that night was MIDI editing, not exactly a stress test. I have never been able to open up that file since and I've tried lots of different ways to do it. I ended up using a back-up version from a week earlier and spending a lot of time and effort reconstructing what I'd done since the last backup. Hopefully, your situation will have an easier resolution. I since got rid of that G4/5.01/10.4.6 setup and moved to an iMac/5.11/10.4.9 and haven't had a problem like that since. Now I "save copy as" every hour or two. Good luck.
chucks
Post by chucks »
There may be other causes of a -43 error, but if the .L and .R files for a stereo audio track are not in the same folder, you get the -43 error. It is easily reproduced, just drag either a .L or a .R file without its mate from the audio files folder in your project folder to anywhere else and then open the project. *ID -43*. You can look for lone .L or .R files in the audio files folder (or wherever you keep them) and either find their mates and reunite them or delete the lone file. If you delete the lone file you get the missing files dialog when the project opens.
ozheri
thanks all
Post by ozheri »
chucks you got it!!
i had dragged a file "blah".L out of the audio files, when reunited with its mate , it opened. :D
motu 828(oldie)
REASON,MELODYNE
dweiss
Post by dweiss »
Wow! That's a bug if there ever was one. DP should be smart enough to be able to deal with that.
tikibars
Post by tikibars »
I get a different version of error -43.
When I try to drag-and-drop a stereo AIF file from a finder window into a DP 5.1 track, I sometimes get "Mac OS Error File Not Found (-43)".
Trying to import the same files using the Import Audio command gets me the same error message.
The files is question were created by DP using the Export Selected Bites command in the Soundbites window's main menu.
These AIF files play back fine from the CD that I burned them to, and even things like Reason's file browser window and Toast's audio CD page will recognize and play them.
DP, their creator, has orphaned and abandoned them.
Pound
Post by Pound »
Use Disk Warrior on the drive and it will fix it. At least it should. I had the same thing happen to me and disk warrior fixed it.
Macbook Pro
OS X 10.4.11
DP 5.12
Motu Ultralite
tikibars
Post by tikibars »
There is an even easier fix:
I went into DPs preferences, and mucked around a bit, just clicking and tweaking a few things. After I did that - changing nothing related to the problem, because there ARE NO prefs related to the problem - everything was hunky dory.
I guess the prefs file was re-written after I changed some stuff....
