import sample, select a section, selection to loop, change loop type to "alternate with crossfade". it will crash DP511 for me every time.
g5 dual 2g, os 10.4.9
also, I saved a preset of my own in m5. when I pull it up it's correct but the filter section is all set to defaults even though I can hear them. in other words, it says "no drive" and the knob is at "0" but I can hear the drive. if I turn the drive knob it changes, still saying "no drive". same with all the filter settings, they're all at defaults, but I can hear the sweeps and such that I set up. clicking on the knobs and moving them doesn't do anything to correct it.
I'm very new to m5 so I may be doing something wrong. I've actually had it for a year or two but have never really used it much. I'm trying to see if I can use it for the way I like to work.
thanks for your help
bb
how to make m5 crash...
Re: how to make m5 crash...
Here is what I did:bongo_x wrote:import sample, select a section, selection to loop, change loop type to "alternate with crossfade". it will crash DP511 for me every time.
g5 dual 2g, os 10.4.9...
••• Imported a sample
••• Selected a section
••• Set selection to loop
••• Changed loop type to "alternate with crossfade."
Result: Works great.
My system:
G5 PPC, 4GB RAM, Dual 2.0, OS X.4.9, MachFive 1.2.3; DP 5.11
You can't be on an Intel Mac with MachFive, the only thing that might be different from my system would be RAM.
gremlins!
