Digital Performer Tips, Edited
- Shooshie
=-=-=-=-=-=-=-=-=-=Digital Performer Tips=-=-=-=-=-=-=-=-=-=
for more efficient usage and mastery of the medium
gleaned from the pages of the Unicornation Forum
recompiled and edited
If this is your first time to read the tips, please take a moment to scroll to the end of the file and read the copyright info (basically conditional freeware) and the disclaimer (don't hold us responsible, etc). It was here at the beginning, but I moved it because it seemed obtrusive in this position. I'd rather get right down to the tips, first off, so that the file is inviting to use over and over.
INTRODUCTION
It started with a thread in the Digital Performer forum at Unicornation: Topic: Share your favorite DP tip! Or, things you wish someone had told you about without having to learn the hard way. Here, I have attempted to group the tips for easier reference, and I've mentioned the name of the tipster only in italics at the end of each tip. It's important that people be recognized for their contributions, but the most important thing here is that the tips are easy to find and easy to use. Tips that I've added here that do not appear in the original forum thread are credited to [Editor]. (That would be me: Shooshie) Much work remains to organize the tips better, but that will come later. For now, let's keep adding those tips!
Thanks to all at Unicornation who contributed to this thread and made it possible! If your name doesn't appear, and you think it should, please write me and tell me. Sometimes two people reported the same tip. Anyway, THANKS TO EVERYONE! This is a great group of people!
THE TIPS
[Editor's Note: These tips are not guaranteed. In fact, nobody can be sure that they cannot destroy your computer and burn down your house. We're assuming you can surmise the risks yourself. Read the disclaimer at the end of the file before attempting any tips. Your decision to try these tips will be considered proof of your willingness to accept responsibility for whatever happens! We know you know what we mean, but we gotta say it, anyway, because people say there are people out there who would do bad things to all of us if they could hold us legally responsible for their own problems, which they cannot, since they're using tips that are not guaranteed to work, and about which they have been duly warned. That said, we hope you enjoy what you learn here, and that you won't use it to burn down anyone's house. Please. Ok? Fine.]
Category: Computers 101
Tip Number One: BACKUP
Works: everywhere
Make reliable backups of all data before attempting any shortcut or procedure in this document. It's a good habit, no matter your intents and purposes. Learn from the DP manual what to look for in the folder of a saved project, and back up all of it. You will probably need to use your backups at some time in your career with Digital Performer, though most users can vouch for the fact that it is rare, and that DP is a very stable application. That does not excuse the need for a reliable backup to good CD, DVD, or hard drive media.
Audio should be saved as-is, and not converted into other forms for archiving. Nor should audio files be compressed for archiving.
It has been said by Apple "geniuses" that backups to CD or DVD should be burned at a slow speed to increase the reliability and durability of the discs, the argument being that the longer the laser is in contact with the media substrate, the more defined will be the holes it burns in that substrate, and the lower the chance for error or abnormal deterioration. I repeat that here for your consideration, but I cannot vouch for its accuracy. I treat it as the truth, myself.
In addition to restoring the documents later, it is also possible to restore portions of a Digital Performer document by using the "Load" command under the FILE menu. From this dialog, one can copy chunks, songs, soundbites, effects settings, and many other parameters, loading them into a new file as desired.
_________________________
Category: MIXING
Automation when Mixing
Works in: Mixing Board, Sequence Window
Turn off the automation prefs under the setup window called 'effects parameter' before every mix and/or turn off the automation "write" button. When you are mixing in a DAW, it can be too easy to automate nearly everything. EQ's, mutes, pans, volumes, sends and everything else are subsequently automated if the write buttons are left on accidently when you are previewing any settings during playback. If you are panning or muting tracks just to hear how things sound, you can leave behind a trail of automation that can be ridiculously hard to clean up later. So, turn off the red automation record (write) button on all tracks, and only turn on the ones you actually want to write to. Be sure to set up your automation prefs so that you don't record automation you don't want.
Timeline
Category: MIXING
Automation
Snapshot Automation finishes out track settings
Works in: Sequence Editor and Mixing Board
Snapshots can set effects settings automation to the desired position all the way to the end of a track. Look up Snapshot, Automation in index of manual. Current at time of this writing (July, 2005), page 703.
________________
TheHopiWay
Category: MIXING
Snapshot Automation for copying effects settings to another location
Page 706 in manual. Follow instructions carefully and you can copy effects settings from one place to another by
1) position playback wiper where you want to copy automation settings,
2) globally disable automation
3) move to new location
4) globally enable automation
5) Be Careful: DO NOT MOVE wiper or budge Transport Counter at this point
6) take automation snapshot
7) snapshot will copy settings as they were in the original location, and apply them at the point where you took the snapshot (new location)
______
[Editor]
••••••••••••GROUPS••••••••••••
Grouping Tracks to perform simultaneous operations
[Editor's Note: if you have "Suspend Track Groups" selected under PROJECTS••â€
INTRODUCTION
THE TIPS
Works: everywhere
Category: MIXING
Timeline
Category: MIXING
Automation
________________
TheHopiWay
Category: MIXING
______
[Editor]
- sdfalk
Re: Digital Performer Tips, Edited
Thanks very much for this Mr S and to all those who contributed tips.
A Metric Halo ULN8-3D…mmmmmmm
great piece of work bringing it together - we'll call this the "other" manual !
Nice work Shoosie~! Very helpful indeed and saves wading through pages and pages of great tips...
Fyrshroud
SD Productions
SD Productions
Many thanks to you Mr Shooshie and to all the guys the contributed to this golden gift!!!
Cheers
Arceo
Cheers
Arceo
- BKK-OZ
OK, I'll admit it, Shooshie is good for sumthin' after all. My tiny tiny tiny contribution will be to ask J Steele if he will make this a sticky.
Cheers,
BK
- M Kaku
BK
- M Kaku
- richard
Thanks and great job!
Richard Temple
G5 2x2 4.5Gb, MacBook, 828mkII, Tascam FW 1804, DP, Logic, Giga, MachV, Reason, Live, EW Gold, Stormdrums, Atmosphere....
www.mutexmusic.com
www.mutexmusic.com
I support that request.Originally posted by BKK-OZ:
Thanks for the comp work, Shooshie. Thanks all for the contributions.
Thanks Mr. Shooshie!
Great family and friends!
F. Douglas
F. Douglas
Thank again Shooshie! Great job!
wow.
you sir are a true gentleman.
i have to second that sticky request.
thank you, Mr. S!
FM
FM would rather dan than dan rather.
thank you, Mr. S!
FM
no seriously...thanks
Brett
Brett
- qo
I think JS should make Shooshie a Sticky
Very nice contribution Shooshie.
Thank you very much for the compiler and contributors.
Thank you for your continuing generosity--you have helped me more ways than you know. And thanks to all the tipsters.
peace
peace
Mac Pro Quad 2.66 5gigs ram, OSX.6.1, DP 7.02 Apogee ADX 16, Mytec DAC, Mackie MCU, MTP-AV, Stylus RMX, Ivory, EWQL, Plug Sound Pro, Mach V, Reason, MX4, Ethno-instrument, Virtual Guitarist2, Do I really need all this stuff? UAD-1,2, Waves L3, PSP, Altiverb, Neodynium, AT 5 various other plugz.
