Send not going to an Output
I have 4 Aux's set up for a mix. Aux1(stereo) Drums, Aux2(mono) Bass, Aux3 (stereo)Guitars, Aux4 (mono)Vocals. In each Aux I have a send that is assigned to a physical output of my HD192 that feeds my Aviom headphone system. Aux1(send out 3&4)
Aux2(send out 5) Aux3 (send out 7&8) Aux4 (send out 6) For some reason I am getting no output on my HD192 Out 5. Any ideas?
G5 2Ghz, 3.5 MB RAM, DP5.13, HD192, Micro Express, Mackie MCU, Mach V.PSP Vintage Warmer, PSP Lexicon42, Sonalksis SV-315Mk2, Altiverb, URS-A URS_N series, Waves Z-Noise, PSP Xenon, PSP MasterQ, Ivory, NI B4, Arturia Moog Modular.
check your audio bundles---
also, double check your "ins"-- which tracks and aux's are set to receive "from" their desired sources...
Another thought-- double check your studio settings to make sure you've assigned enough tracks to your project...
- Spikey Horse
OK I've checked al the things mentioned and everything checks out. The thing is these send were working correctly in the beggining of the session. When I disable the send and re apply it to the second send slot everything works. Strange! Any more ideas?
Any other experiences of this or suggestions? Again Send 1 is lets say (HD192_Out 3&4). No signal being sent. Select none for send one assign send 2 of the same track to (HD192_Out 3&4) and it sends out fine. I've had it happen in the middle of a session where it was working fine and then would not output anything.
My master fader is set to outputs 1&2. This is my main output to my monitors so I don't think this is the case. Like I said also it does work and then doesn't midway through a project.
