Send not going to an Output
kid
Post by kid »
I have 4 Aux's set up for a mix. Aux1(stereo) Drums, Aux2(mono) Bass, Aux3 (stereo)Guitars, Aux4 (mono)Vocals. In each Aux I have a send that is assigned to a physical output of my HD192 that feeds my Aviom headphone system. Aux1(send out 3&4)
Aux2(send out 5) Aux3 (send out 7&8) Aux4 (send out 6) For some reason I am getting no output on my HD192 Out 5. Any ideas?
G5 2Ghz, 3.5 MB RAM, DP5.13, HD192, Micro Express, Mackie MCU, Mach V.PSP Vintage Warmer, PSP Lexicon42, Sonalksis SV-315Mk2, Altiverb, URS-A URS_N series, Waves Z-Noise, PSP Xenon, PSP MasterQ, Ivory, NI B4, Arturia Moog Modular.
Frodo
Post by Frodo »
check your audio bundles---
also, double check your "ins"-- which tracks and aux's are set to receive "from" their desired sources...
Another thought-- double check your studio settings to make sure you've assigned enough tracks to your project...
iMAS
Post by iMAS »
Hi kid,
I have the HD192 unit also. To add to what Frodo said, you might also want to double check the "Motu PCI Audio Setup" in the applications folder and make sure all the input and outputs (1-12) are enabled.
Spikey Horse
Post by Spikey Horse »
Just throwing in a 'silly' ... have you turned the send pots up?
kid
Post by kid »
OK I've checked al the things mentioned and everything checks out. The thing is these send were working correctly in the beggining of the session. When I disable the send and re apply it to the second send slot everything works. Strange! Any more ideas?
kid
Post by kid »
Any other experiences of this or suggestions? Again Send 1 is lets say (HD192_Out 3&4). No signal being sent. Select none for send one assign send 2 of the same track to (HD192_Out 3&4) and it sends out fine. I've had it happen in the middle of a session where it was working fine and then would not output anything.
ba_hill
Post by ba_hill »
I think there's an bug(?) with DP that it doesn't output ANY audio if outs 1&2 don't have any audio on them. Try moving one of your output pairs to outs 1&2.
Brian
kid
Post by kid »
My master fader is set to outputs 1&2. This is my main output to my monitors so I don't think this is the case. Like I said also it does work and then doesn't midway through a project.
