Which drive to install MSI?
Discussion of all things related to the MOTU Symphonic Instrument.
Diazruanova
Post by Diazruanova »
Hi,
I just ordered my MSI copy and was wondering into which drive to install it:
I have an iMac 17" Core2 Duo 2.0G with an internal drive of 160 G and an external USB 2- 160G Barracuda 7200.
Now, I understand for what I have read, that MSI comes separated into the Library section and the program itself, so I was thinking installing each section into a different drive for example, the prog. into the main drive and the Library on the external.
Do I make any sense with this question ?
Thanks guys.
Enrique
Windows 7 Home Premium 64bit
CPU: Intel Core i7 860 @ 2940 MHz // GPU: ATI-Radeon HD 5670
MotherBoard: Gigabyte H55M-USB3 // RAM: 8Gb // Audio Card: Audio Card: M-Audio Audiophile 2496
Cubase 6 x 64 Bit 6.0.4
The Grand 3 ver. 3.1.1 64Bit // Halion Symphonic Orchestra 1.5.0 x 64 Bit
EWQLSO Symphonic Orchestra GOLD 64Bit (Play 3.0.21)
mikebeckmotu
Post by mikebeckmotu »
I've found it best for my purposes to have a dedicated drive for samples and a dedicated drive for my recorded tracks. I've been using a Powerbook with two external firewire drives, which i just hooked up to my new iMac (same one you have). I'd recommend putting the samples on your external drive.
Being that OSX uses your startup drive for virtual memory and applications, this keeps the drive head from having to jump all around to read samples, write to virtual memory and record. You may want to invest in one more drive for your projects if you have any troubles.
8-core i9 MacBookPro 16-inch, 16gb ram, Catalina, Focusrite Scarlett 18i8, DP not installed yet
Diazruanova
Thank you very much mikebeckmotu.
Since I am planning to do mostly MIDI recordings with very few audio tracks, I think that for now, I'll stay with just one ext. drive and have the samples installed on it, following your advice.
Greetings from Mexico!
mikebeckmotu
That should work well.
Good luck! Let us know how it all works out.
daniel.sneed
Post by daniel.sneed »
I would keep a different partition on the external drive, exclusively for the samples.
Diazruanova
daniel.sneed wrote:I would keep a different partition on the external drive, exclusively for the samples.
Yes, in fact I already have an empty partition, which I'll dedicate exclusively for the samples.
