Is DP 4.61 compatible with OS 10.4.8?
blue
Post by blue »
I just upgraded to 10.4.8 (as per MOTU's recommendations for DP 5.11) and now DP 4.61 crashes every time I try to make an audio selection. More specifically, MAS shuts down. When I try to reboot the audio system, I get stuck in a dialog box loop that tells me to change settings. But no change will bring MAS back. If I cancel the dialog box, crash!
Unfortunately, I have some older DP 4.61 files I can only open in 4.61. They use some MAS-only plugs that aren't (and never will be) UB. (Damn you Antares!)
Is anybody else able to use 4.61 with OS 10.4.8?
jrdmcdnld
Post by jrdmcdnld »
I'm using DP4.6 (not4.61) with OSX 10.4.8 on a 1.33 G4. I have no problems. What machine are you using?
Did you try repair permissions?
abe_lincoln78
Post by abe_lincoln78 »
Works great on my G5 with 10.4.8. I've been meaning to upgrade to DP5 though, but I am going to wait until I have money, an interface that isn't crap (don't ever buy an M-Audio unit. . . they have the WORST DRIVERS EVER!!!), and most importantly, I am waiting for people to stop complaining about things that don't work.
Until then, its processor spikes, blips, clicks, etc. . . .
He said now son, your gonna drive me to drinkin, if you don't stop drivin that hot . rod . lincoln
My father ;)
empirepd
Post by empirepd »
I use DP 4.61 and just upgraded from OS 10.3.9 to 10.4.8 and it works fine. However, I still have DP 4 and DP 4.12 on my machine and I tried to run a sequence in DP 4.12 and DP crashes. Is DP 4.12 compatible with OS 10.4?
Buzzy
Post by Buzzy »
empirepd wrote:I use DP 4.61 and just upgraded from OS 10.3.9 to 10.4.8 and it works fine. However, I still have DP 4 and DP 4.12 on my machine and I tried to run a sequence in DP 4.12 and DP crashes. Is DP 4.12 compatible with OS 10.4?
DP 4.12 is not compatible with 'tiger' (10.4).
.bzz...
blue
Post by blue »
Thanks for the replies, guys. I'm happy to know the two can get along together.
When I upgraded to 10.4.8, I repaired permissions before and after. Then, I started having issues with DP5.11 crashing on startup. So, I trashed the preferences and resolved a few plugin issues related to some custom folders I had created. Now 5.11 is fine.
I will have to do some more digging around to see what the problem is on my end with 4.6.
By the way, my interfaces are an 828mk2 and a microlite.
emulatorloo
Post by emulatorloo »
abe_lincoln78 wrote:I've been meaning to upgrade to DP5 though <snip> and most importantly, I am waiting for people to stop complaining about things that don't work.
People on the internet always complain. Can you imagine a thread:
HELP! DP 5 IS WORKING GREAT>
-- so don't wait forever to get DP 5. For me 5.11 is more stable and more efficient than any version of DP 4. (dual g4 1.3)
