For some reason, when I click on the output bar for my MIDI stuff, I get 11 duplicates of each MIDI choice.
I can still choose the MIDI output I want, but.....
Is there a way to thin this out to normal?
Thanks.
Too many duplicates in MIDI output column
- waterstrum
Supplementary question:
I've a set of dupes that's hung around for 2 years - PODxt and Bass PODxt.
It's mildly annoying having to carefully make selections, but it's only a pair of dupes.
Waterstrum's problem of 11 dupes of each choice sounds like a nightmare!
We both await a Unicorn in shining white... fur.
MM
MM
Wow, Steve.
Having tried many things and given up a year ago, I've been waiting on an insight like that.
I've glanced at but not checked the list in that window, as I use AMS.
An inadvertent duplicating of a selection in this window could explain it, in theory at least.
I'm not able to check it out right now, but can't wait for that next boot-up tomorrow!
Thanks heaps, Steve; hopefully it helps waterstrum, if not the monkey.
Nicky
Nicky
- waterstrum
Doh! No go.
No dupes in DP's MIDI "bundle" list.
The quest for a solution continues with more stone-turning...
