Windows Xp Firewire/Usb Drivers V 3.6.7.3 ?? Whats New ??
edwardb
Post by edwardb »
Anyone know exactly what the new version driver actually updates ? I am assuming it allows for proper detection of the new 8PRE Motu hardware.......Anybody else have more info ?
(Version 3.6.7.0 update to Version 3.6.7.3)
Asus PC-DL Deluxe Server Motherboard
Dual Intel Xeon 3.2 Ghz 2Mb L3 Cache 533 Fsb
Intel 875 Chipset, 4 Gb Ram, 256 Mb Agp 8X Video
Belkin Firewire Pci
Maxtor Sata 7200 rpm 16 Mb Cache 250 Gb X 3
Dual Motu 896HD Firewire Interface
Presonus Digimax LT Pre-Amp
Windows Xp Pro Sp1, Sonar 6 Producer
Native Instruments Komplete 3
cybergrass
Re: Windows Xp Firewire/Usb Drivers V 3.6.7.3 ?? Whats New ?
Post by cybergrass »
Bump :?:
edwardb
Post by edwardb »
What does "Bump" mean ??
Belkin Firewire Pci
Bagico
Post by Bagico »
Bump means "Bump". Nobody knows nothing about de new driver. I think that MOTU don‘t knows too. :?:
arth
Post by arth »
edwardb wrote:Anyone know exactly what the new version driver actually updates ? I am assuming it allows for proper detection of the new 8PRE Motu hardware.......Anybody else have more info ?
If MOTU follow standard versioning conventions, there will be no functionality changes at all for a minor subrevision change.
project
Post by project »
you guys didnt read the PDF on the download page? 8)
Core 2 Duo. E6600
4GB RAM
Vista 64
ASUS P5B
Cubase 4
MOTU Ultralite
SIIG PCIE 2-port firewire
dagnilsen
Post by dagnilsen »
It's from 2004!
fnord
Post by fnord »
I talked to MOTU support because the new driver would not install on any non-english Windows XP. (That they admitted - however no fix so far.) The more important information is that it wouldn't do anything for me with my 828mkII anyways. The only improvement is for some newer MOTU device (I forgot which one - sorry). So don't bother. Release Notes are for wimps....
fnord
jkromm1
Post by jkromm1 »
I got a MOTU 896 off ebay, used the drivers that came on CD with it (probably old as hell) tried to download new drivers big mistake, didn't work at all. My lesson if it works don't worry about it.
Acidfever
Post by Acidfever »
Did anyone check if this driver accidentally fixes the problem with ADAT i/o not showing up in your host in windows systems?
espe3000
Not at all
Post by espe3000 »
The latest driver of PCI-324 (Windows XP Pro version) doesn't fix the issue of ADAT I/O not showing in Motu Audio Console.
I really don't understand how is this possible. I was using an old version of driver, and it was ok. I re-installed my computer but couldn't find the former driver I was using. So, I downloaded the new one. I lost all I/O.
It looks like the PCi-324 is no more able to see my 2408 module.
Does someone have the version before the latest one (3.64)?
Maybe it is my 2408 that is dead (at least the 1394 connection). Is this possible? How can I check that data are going through?
Thanks to anyone who will help
Paul
Espe
Atardecer
Post by Atardecer »
From what i understand there is no difference for 828 users. The new drivers were revised to incorporate drivers for the ultralite and whatever else is new (8pre??). Personally the new drivers crashed my system (i have an 828 MKII). 3.5.3.2 drivers seem to work best for myself and many others. There doesnt really seem to be any need to get these drivers unless you have a new MOTU product.
Regards
fnord
Post by fnord »
exactly. no bugfixes. adat not showing problem perists throughout all versions. i have it, too. workaround: open the audio console, switch off adat, switch it back on. hit "ok". now your adat ports show up in windows and/or your asio based audio host application.
fnord
espe3000
Post by espe3000 »
Hi fnord,
I am wondering how you made it. What do you mean by "switching off/on adat"?
Here is my config:
- Motu PCI-324 inside a PC with Windows XP Pro SP2
- Motu 2408
- Alesis ADAT LX 20
- Yamaha 01V
I have installed and re-installed so many times, I am really tired with this.
Sometimes I get the message "Wave Driver for PCI-324 'This device cannot start (code 10)" when I review devices in Windows device manager
Do you know is going on, did you face same issues such as this one?
You are talking about driver version 3.5 - Could you provide me with that version, maybe by e-mail?
Thanks in advance
Paul
Espe
fnord
Post by fnord »
sorry, paul. I have the 828mII. dosn't compare to what's going on with your setup.
fnord
