Careful with typos in track names
Just a heads-up - had an audio track behave weird. Couldn't use "Repeat" command, wouldn't let me select it under certain circumstances for a paste, etc.
As I look at the offending track I realized I had accidentally typed "DrsScratch[rint" instead of "DrsScratchprint" (letter "p" being next to the square brackets on the US keyboard.) After I replaced the bracket with the regular letter the track behaved fine.
Hmmmm.
Anyway, problem gone and I like the proper track name better anyway. Just FYI, should anyone else ever run into this...
Hmmmm.
Re: Careful with typos in track names
Hmm, I did have a situation once where a song was crashing repeatedly. Nothing seemed to work. Just on a whim, I re-named the project, and all worked fine. I didn't have any special characters in the name though. It was a joke for quite a while with that client. The song was "Last Waltz." I re-named it "Not The First Waltz." Oh well!
Phil
Phil
- frankymax
Yes- I remember a problem similar to this several months back where trying to show a track in Quickscribe which had a special character in its track name caused DP to lock up and crash. We finally figured out that by renaming the track without any special characters it would behave properly. I guess there's something odd with certain special characters in the track names!
DP9/Windows7-64bit-32GBRAM Intel i7-3e930K CPU@3.2GHz/Lynx Aurora 8/VSL Ext.Lib//Komplete8/Spectrasonics/KorgLegDig/Valhalla/WavesMus2/iZotope/PSP/CytomicGlue/NomadPP/Plug&Mix/DynSpecM/KurzPC88/LexiNatBundle/RelabLX480/Kush/FabFilter/Finale/Sibelius/PacificaMicPre/Lawson/Neumann/Peluso/AKG/SeNeve/Lucas Mics/Genelec1032A
http://frankmacchia.net/
I guess Shakespeare was wrong. A ro$e by any other name doe$ not $mell [a$] $weet.
- mhschmieder
That's good to know about. Do we know which characters are specifically to be avoided? I use my track names to document which patches I use (I NEVER use patch selection features in a DAW, and Reset All Controller etc. at the start of every MIDI track). This means they contain special characters, and these often get converted in the actual on-disc filename whether recording real-time or using BTD. yet not always (colons sometimes are retained, and parentheses seem to be accepted as valid characters IIRC).
- frankymax
this was a while ago, but if memory serves me correct it might have been the % sign- I think the track name had the patch name of a Roland sample which used the % sign - but I'm not absolutely sure.
- KEVORKIAN
Interesting... a lot of symbols like [ % / * etc are used in C programming (and at the unix command line) to represent variables and expressions.frankymax wrote:this was a while ago, but if memory serves me correct it might have been the % sign- I think the track name had the patch name of a Roland sample which used the % sign - but I'm not absolutely sure.
I would imagine that there could be some instances where DP would try to pass the track name along with a given command and such an unexpected symbol could be seen as a portion of data relevant to the command. This may be something that MOTU should consider looking into if repeatable (I'm not volunteering to test this one btw! )
dp7.2 || os 10.6.7 || 2x2.8 (eight core) intel mac pro, 16gb ram || metric halo uln-8 || motu traveler || euphonix mc control || waves mercury || abbey road bundle || mh channelstrip || toontrack sd 2.0, ez drummer, drumtracker || addictive drums || drumcore 3 || ni komplete 5 || reason || bidule || altiverb 6 || omnisphere, stylus RMX || melodyne 3.2 || stillwell || soundtoys || nomad factory|| psp || mpressor || dsm ||
