QUicktime musical instruments?
Hi
Anyone knows how to access Quicktime Synth in DP 4? I can t find it in th audio-video setup and I know its in the system
- buzzsmith
I never found it, either.
I ended up just using the Apple Software Synth to preview exisiting commercial or free MIDI files, etc.
=bz=
=bz=
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- joelmusic
i've been trying to get MIDI out of my laptop unsuccessfully for a long time now. on my g5, i route it through a mtpav, but to just get sound out of my laptop, there is only the elusive iac driver, which routes MIDI to another application. so, i figured, maybe i can route it from d.p. to quicktime. no such luck.
anyone have any answers? should be the easiest thing in the world, and it used to be when you would select quicktime in free MIDI.
- joelmusic
actually, i figured it out!
on motu.com no less... whodathunkit?
in performer, the drop down menu
setup/ interapplication MIDI
from there, check the "interapplication MIDI" box, and make sure it is assigned to apple software synth. then assign the outputs to the software synth and you're in business... good for referencing things for me when i'm away from my system...
- taggart
Wow! MOTU has the answers for their own products!
Very cool. I'd be interested to see how much of a CPU load QT gives you. I thought I read elsewhere on here that the Quicktime synth was a bit of a processor hog. That's probably why I had mine disabled. Keep us posted, joelmusic!
Taggart
Mac Mini
DP 11
Reason, and various plug-ins, VI's and such.
Mac Mini
DP 11
- taggart
(Sorry for the double post. Is there a way to get rid of ONE of them? Just curious.)
Taggart
Mac Mini
DP 11
Mac Mini
DP 11
Here's some additional info that might be relevant to you...
The Quicktime "Apple DLS instrument" is configurable in DP and can be of great value when you need a bank of GM instruments; however there is another hurdle one has to overcome when dealing with "patch numbers" and not knowing which sound they actually represent - flute, sawtooth, piano, finger-bass, or what...etc.
Here's a text I lifted off from some forum (I can't temember which) that can help one put actual names to these patch numbers - GM names that is. And, I've done it myself and it works!
Read on and see if it can be of further use to you
The excerp reads as follows.....
Hi. I'm really embarassed to ask this dumb, basic question, but it's driving me nuts trying to figure this one out:
I actually use the Apple DLS general MIDI softsynth from time to time when I get a midifile from a client and just want to get a rough idea of what's going on musically in their sequence. However, there doesn't seem to be a list of instrument names under default patch lists, so it's very hard to pick a corresponding sound to go with whatever type sound is sequenced on the track. Is there a way to assign names (even if I have to do it patch by patch) to the DLS patches. Currently they just say patch 1 thru patch 127. I know in OS 9 on DP3 the Quicktime instrument did have the patch names, even separated into banks by in st groups (ie: Keyboards, Guitars, Reeds, Brass etc). Why would Apple's instrument on OSX not have names!?
Thanks for any help.
-Frank
PS- Happy New Year
Let's see if this will work. Just below is the text of the file "Default Names.midnam". Try to copy this into TextEdit, then save it with the file name above. Then navigate to: yourharddrive/Library/Audio/MIDI Devices/MOTU. In that folder, find Default Names.midnam and trash it. Take the new Default Names.midnam, and drag it to that folder. Now when you open DP, your DLS Instrument should show General MIDI patch names in the Default Patch column. I'm not sure if this will work, but I thought I'd try to help. If it doesn't work, re-claim your original file from the trash(and accept my apologies!). Here's the text to copy and paste-good luck!:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE MIDINameDocument PUBLIC "-//MIDI Manufacturers Association//DTD MIDINameDocument 0.7//EN" "http://www.sonosphere.com/dtds/MIDINameDocument.dtd">
<MIDINameDocument>
<Author>Mark of the Unicorn - converted from FreeMIDI</Author>
<StandardDeviceMode Name="Default Names" >
<ChannelNameSetAssignments>
<ChannelNameSetAssign Channel="1" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="2" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="3" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="4" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="5" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="6" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="7" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="8" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="9" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="10" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="11" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="12" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="13" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="14" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="15" NameSet="Name Set 1" />
<ChannelNameSetAssign Channel="16" NameSet="Name Set 1" />
</ChannelNameSetAssignments>
<ChannelNameSet Name="Name Set 1" >
<AvailableForChannels>
<AvailableChannel Channel="1" Available="true" />
<AvailableChannel Channel="2" Available="true" />
<AvailableChannel Channel="3" Available="true" />
<AvailableChannel Channel="4" Available="true" />
<AvailableChannel Channel="5" Available="true" />
<AvailableChannel Channel="6" Available="true" />
<AvailableChannel Channel="7" Available="true" />
<AvailableChannel Channel="8" Available="true" />
<AvailableChannel Channel="9" Available="true" />
<AvailableChannel Channel="10" Available="true" />
<AvailableChannel Channel="11" Available="true" />
<AvailableChannel Channel="12" Available="true" />
<AvailableChannel Channel="13" Available="true" />
<AvailableChannel Channel="14" Available="true" />
<AvailableChannel Channel="15" Available="true" />
<AvailableChannel Channel="16" Available="true" />
</AvailableForChannels>
<PatchBank Name="Patch Names" >
<PatchNameList>
<Patch Number="001" Name="Acoustic Grand Piano" ProgramChange="0" />
<Patch Number="002" Name="Bright Acoustic Piano" ProgramChange="1" />
<Patch Number="003" Name="Electric Grand Piano" ProgramChange="2" />
<Patch Number="004" Name="Honky-Tonk Piano" ProgramChange="3" />
<Patch Number="005" Name="Electric Piano 1" ProgramChange="4" />
<Patch Number="006" Name="Electric Piano 2" ProgramChange="5" />
<Patch Number="007" Name="Harpsichord" ProgramChange="6" />
<Patch Number="008" Name="Clavinet" ProgramChange="7" />
<Patch Number="009" Name="Celesta" ProgramChange="8" />
<Patch Number="010" Name="Glockenspiel" ProgramChange="9" />
<Patch Number="011" Name="Music Box" ProgramChange="10" />
<Patch Number="012" Name="Vibraphone" ProgramChange="11" />
<Patch Number="013" Name="Marimba" ProgramChange="12" />
<Patch Number="014" Name="Xylophone" ProgramChange="13" />
<Patch Number="015" Name="Tubular Bells" ProgramChange="14" />
<Patch Number="016" Name="Dulcimer" ProgramChange="15" />
<Patch Number="017" Name="Drawbar Organ" ProgramChange="16" />
<Patch Number="018" Name="Percussive Organ" ProgramChange="17" />
<Patch Number="019" Name="Rock Organ" ProgramChange="18" />
<Patch Number="020" Name="Church Organ" ProgramChange="19" />
<Patch Number="021" Name="Reed Organ" ProgramChange="20" />
<Patch Number="022" Name="Accordion" ProgramChange="21" />
<Patch Number="023" Name="Harmonica" ProgramChange="22" />
<Patch Number="024" Name="Tango Accordion" ProgramChange="23" />
<Patch Number="025" Name="Nylon String Guitar" ProgramChange="24" />
<Patch Number="026" Name="Steel String Guitar" ProgramChange="25" />
<Patch Number="027" Name="Jazz Guitar" ProgramChange="26" />
<Patch Number="028" Name="Clean Guitar" ProgramChange="27" />
<Patch Number="029" Name="Muted Guitar" ProgramChange="28" />
<Patch Number="030" Name="Overdriven Guitar" ProgramChange="29" />
<Patch Number="031" Name="Distortion Guitar" ProgramChange="30" />
<Patch Number="032" Name="Guitar Harmonics" ProgramChange="31" />
<Patch Number="033" Name="Acoustic Bass" ProgramChange="32" />
<Patch Number="034" Name="Fingered Bass" ProgramChange="33" />
<Patch Number="035" Name="Picked Bass" ProgramChange="34" />
<Patch Number="036" Name="Fretless Bass" ProgramChange="35" />
<Patch Number="037" Name="Slap Bass 1" ProgramChange="36" />
<Patch Number="038" Name="Slap Bass 2" ProgramChange="37" />
<Patch Number="039" Name="Synth Bass 1" ProgramChange="38" />
<Patch Number="040" Name="Synth Bass 2" ProgramChange="39" />
<Patch Number="041" Name="Violin" ProgramChange="40" />
<Patch Number="042" Name="Viola" ProgramChange="41" />
<Patch Number="043" Name="Cello" ProgramChange="42" />
<Patch Number="044" Name="Contrabass" ProgramChange="43" />
<Patch Number="045" Name="Tremolo Strings" ProgramChange="44" />
<Patch Number="046" Name="Pizzicato Strings" ProgramChange="45" />
<Patch Number="047" Name="Orchestral Harp" ProgramChange="46" />
<Patch Number="048" Name="Timpani" ProgramChange="47" />
<Patch Number="049" Name="String Ensemble 1" ProgramChange="48" />
<Patch Number="050" Name="String Ensemble 2" ProgramChange="49" />
<Patch Number="051" Name="Synth Strings 1" ProgramChange="50" />
<Patch Number="052" Name="Synth Strings 2" ProgramChange="51" />
<Patch Number="053" Name="Choir Aahs" ProgramChange="52" />
<Patch Number="054" Name="Voice Oohs" ProgramChange="53" />
<Patch Number="055" Name="Synth Voice" ProgramChange="54" />
<Patch Number="056" Name="Orchestra Hit" ProgramChange="55" />
<Patch Number="057" Name="Trumpet" ProgramChange="56" />
<Patch Number="058" Name="Trombone" ProgramChange="57" />
<Patch Number="059" Name="Tuba" ProgramChange="58" />
<Patch Number="060" Name="Muted Trumpet" ProgramChange="59" />
<Patch Number="061" Name="French Horn" ProgramChange="60" />
<Patch Number="062" Name="Brass Section" ProgramChange="61" />
<Patch Number="063" Name="Synth Brass 1" ProgramChange="62" />
<Patch Number="064" Name="Synth Brass 2" ProgramChange="63" />
<Patch Number="065" Name="Soprano Sax" ProgramChange="64" />
<Patch Number="066" Name="Alto Sax" ProgramChange="65" />
<Patch Number="067" Name="Tenor Sax" ProgramChange="66" />
<Patch Number="068" Name="Baritone Sax" ProgramChange="67" />
<Patch Number="069" Name="Oboe" ProgramChange="68" />
<Patch Number="070" Name="English Horn" ProgramChange="69" />
<Patch Number="071" Name="Bassoon" ProgramChange="70" />
<Patch Number="072" Name="Clarinet" ProgramChange="71" />
<Patch Number="073" Name="Piccolo" ProgramChange="72" />
<Patch Number="074" Name="Flute" ProgramChange="73" />
<Patch Number="075" Name="Recorder" ProgramChange="74" />
<Patch Number="076" Name="Pan Flute" ProgramChange="75" />
<Patch Number="077" Name="Blown Bottle" ProgramChange="76" />
<Patch Number="078" Name="Shakuhachi" ProgramChange="77" />
<Patch Number="079" Name="Whistle" ProgramChange="78" />
<Patch Number="080" Name="Ocarina" ProgramChange="79" />
<Patch Number="081" Name="Square Lead" ProgramChange="80" />
<Patch Number="082" Name="Sawtooth Lead" ProgramChange="81" />
<Patch Number="083" Name="Calliope Lead" ProgramChange="82" />
<Patch Number="084" Name="Chiff Lead" ProgramChange="83" />
<Patch Number="085" Name="Charang Lead" ProgramChange="84" />
<Patch Number="086" Name="Voice Lead" ProgramChange="85" />
<Patch Number="087" Name="Fifths Lead" ProgramChange="86" />
<Patch Number="088" Name="Bass & Lead" ProgramChange="87" />
<Patch Number="089" Name="New Age Pad" ProgramChange="88" />
<Patch Number="090" Name="Warm Pad" ProgramChange="89" />
<Patch Number="091" Name="Polysynth Pad" ProgramChange="90" />
<Patch Number="092" Name="Choir Pad" ProgramChange="91" />
<Patch Number="093" Name="Bowed Pad" ProgramChange="92" />
<Patch Number="094" Name="Metalic Pad" ProgramChange="93" />
<Patch Number="095" Name="Halo Pad" ProgramChange="94" />
<Patch Number="096" Name="Sweep Pad" ProgramChange="95" />
<Patch Number="097" Name="Rain" ProgramChange="96" />
<Patch Number="098" Name="Soundtrack" ProgramChange="97" />
<Patch Number="099" Name="Crystal" ProgramChange="98" />
<Patch Number="100" Name="Atmosphere" ProgramChange="99" />
<Patch Number="101" Name="Brightness" ProgramChange="100" />
<Patch Number="102" Name="Goblins" ProgramChange="101" />
<Patch Number="103" Name="Echoes" ProgramChange="102" />
<Patch Number="104" Name="Sci-Fi" ProgramChange="103" />
<Patch Number="105" Name="Sitar" ProgramChange="104" />
<Patch Number="106" Name="Banjo" ProgramChange="105" />
<Patch Number="107" Name="Shamisen" ProgramChange="106" />
<Patch Number="108" Name="Koto" ProgramChange="107" />
<Patch Number="109" Name="Kalimba" ProgramChange="108" />
<Patch Number="110" Name="Bagpipe" ProgramChange="109" />
<Patch Number="111" Name="Fiddle" ProgramChange="110" />
<Patch Number="112" Name="Shannai" ProgramChange="111" />
<Patch Number="113" Name="Tinkle Bell" ProgramChange="112" />
<Patch Number="114" Name="Agogo" ProgramChange="113" />
<Patch Number="115" Name="Steel Drums" ProgramChange="114" />
<Patch Number="116" Name="Woodblock" ProgramChange="115" />
<Patch Number="117" Name="Taiko Drum" ProgramChange="116" />
<Patch Number="118" Name="Melodic Tom" ProgramChange="117" />
<Patch Number="119" Name="Synth Drum" ProgramChange="118" />
<Patch Number="120" Name="Reverse Cymbal" ProgramChange="119" />
<Patch Number="121" Name="Fret Noise" ProgramChange="120" />
<Patch Number="122" Name="Breath Noise" ProgramChange="121" />
<Patch Number="123" Name="Seashore" ProgramChange="122" />
<Patch Number="124" Name="Bird Tweet" ProgramChange="123" />
<Patch Number="125" Name="Telephone Ring" ProgramChange="124" />
<Patch Number="126" Name="Helicopter" ProgramChange="125" />
<Patch Number="127" Name="Applause" ProgramChange="126" />
<Patch Number="128" Name="Gunshot" ProgramChange="127" />
</PatchNameList>
</PatchBank>
</ChannelNameSet>
<NoteNameList Name="Note Names" >
<Note Number="0" Name="" />
<Note Number="1" Name="" />
<Note Number="2" Name="" />
<Note Number="3" Name="" />
<Note Number="4" Name="" />
<Note Number="5" Name="" />
<Note Number="6" Name="" />
<Note Number="7" Name="" />
<Note Number="8" Name="" />
<Note Number="9" Name="" />
<Note Number="10" Name="" />
<Note Number="11" Name="" />
<Note Number="12" Name="" />
<Note Number="13" Name="" />
<Note Number="14" Name="" />
<Note Number="15" Name="" />
<Note Number="16" Name="" />
<Note Number="17" Name="" />
<Note Number="18" Name="" />
<Note Number="19" Name="" />
<Note Number="20" Name="" />
<Note Number="21" Name="" />
<Note Number="22" Name="" />
<Note Number="23" Name="" />
<Note Number="24" Name="" />
<Note Number="25" Name="" />
<Note Number="26" Name="" />
<Note Number="27" Name="" />
<Note Number="28" Name="" />
<Note Number="29" Name="" />
<Note Number="30" Name="" />
<Note Number="31" Name="" />
<Note Number="32" Name="" />
<Note Number="33" Name="" />
<Note Number="34" Name="" />
<Note Number="35" Name="" />
<Note Number="36" Name="" />
<Note Number="37" Name="" />
<Note Number="38" Name="" />
<Note Number="39" Name="" />
<Note Number="40" Name="" />
<Note Number="41" Name="" />
<Note Number="42" Name="" />
<Note Number="43" Name="" />
<Note Number="44" Name="" />
<Note Number="45" Name="" />
<Note Number="46" Name="" />
<Note Number="47" Name="" />
<Note Number="48" Name="" />
<Note Number="49" Name="" />
<Note Number="50" Name="" />
<Note Number="51" Name="" />
<Note Number="52" Name="" />
<Note Number="53" Name="" />
<Note Number="54" Name="" />
<Note Number="55" Name="" />
<Note Number="56" Name="" />
<Note Number="57" Name="" />
<Note Number="58" Name="" />
<Note Number="59" Name="" />
<Note Number="60" Name="" />
<Note Number="61" Name="" />
<Note Number="62" Name="" />
<Note Number="63" Name="" />
<Note Number="64" Name="" />
<Note Number="65" Name="" />
<Note Number="66" Name="" />
<Note Number="67" Name="" />
<Note Number="68" Name="" />
<Note Number="69" Name="" />
<Note Number="70" Name="" />
<Note Number="71" Name="" />
<Note Number="72" Name="" />
<Note Number="73" Name="" />
<Note Number="74" Name="" />
<Note Number="75" Name="" />
<Note Number="76" Name="" />
<Note Number="77" Name="" />
<Note Number="78" Name="" />
<Note Number="79" Name="" />
<Note Number="80" Name="" />
<Note Number="81" Name="" />
<Note Number="82" Name="" />
<Note Number="83" Name="" />
<Note Number="84" Name="" />
<Note Number="85" Name="" />
<Note Number="86" Name="" />
<Note Number="87" Name="" />
<Note Number="88" Name="" />
<Note Number="89" Name="" />
<Note Number="90" Name="" />
<Note Number="91" Name="" />
<Note Number="92" Name="" />
<Note Number="93" Name="" />
<Note Number="94" Name="" />
<Note Number="95" Name="" />
<Note Number="96" Name="" />
<Note Number="97" Name="" />
<Note Number="98" Name="" />
<Note Number="99" Name="" />
<Note Number="100" Name="" />
<Note Number="101" Name="" />
<Note Number="102" Name="" />
<Note Number="103" Name="" />
<Note Number="104" Name="" />
<Note Number="105" Name="" />
<Note Number="106" Name="" />
<Note Number="107" Name="" />
<Note Number="108" Name="" />
<Note Number="109" Name="" />
<Note Number="110" Name="" />
<Note Number="111" Name="" />
<Note Number="112" Name="" />
<Note Number="113" Name="" />
<Note Number="114" Name="" />
<Note Number="115" Name="" />
<Note Number="116" Name="" />
<Note Number="117" Name="" />
<Note Number="118" Name="" />
<Note Number="119" Name="" />
<Note Number="120" Name="" />
<Note Number="121" Name="" />
<Note Number="122" Name="" />
<Note Number="123" Name="" />
<Note Number="124" Name="" />
<Note Number="125" Name="" />
<Note Number="126" Name="" />
<Note Number="127" Name="" />
</NoteNameList>
<ControlNameList Name="Controller Names" >
<Control Type="7bit" Number="0" Name="Bank Select MSB" />
<Control Type="7bit" Number="1" Name="Modulation Wheel" />
<Control Type="7bit" Number="2" Name="Breath Control" />
<Control Type="7bit" Number="3" Name="" />
<Control Type="7bit" Number="4" Name="Foot Control" />
<Control Type="7bit" Number="5" Name="Portamento Time" />
<Control Type="7bit" Number="6" Name="Data Entry" />
<Control Type="7bit" Number="7" Name="Volume" />
<Control Type="7bit" Number="8" Name="Balance" />
<Control Type="7bit" Number="9" Name="" />
<Control Type="7bit" Number="10" Name="Pan" />
<Control Type="7bit" Number="11" Name="Expression" />
<Control Type="7bit" Number="12" Name="" />
<Control Type="7bit" Number="13" Name="" />
<Control Type="7bit" Number="14" Name="" />
<Control Type="7bit" Number="15" Name="" />
<Control Type="7bit" Number="16" Name="" />
<Control Type="7bit" Number="17" Name="" />
<Control Type="7bit" Number="18" Name="" />
<Control Type="7bit" Number="19" Name="" />
<Control Type="7bit" Number="20" Name="" />
<Control Type="7bit" Number="21" Name="" />
<Control Type="7bit" Number="22" Name="" />
<Control Type="7bit" Number="23" Name="" />
<Control Type="7bit" Number="24" Name="" />
<Control Type="7bit" Number="25" Name="" />
<Control Type="7bit" Number="26" Name="" />
<Control Type="7bit" Number="27" Name="" />
<Control Type="7bit" Number="28" Name="" />
<Control Type="7bit" Number="29" Name="" />
<Control Type="7bit" Number="30" Name="" />
<Control Type="7bit" Number="31" Name="" />
<Control Type="7bit" Number="32" Name="Bank Select LSB" />
<Control Type="7bit" Number="33" Name="Modulation Wheel LSB" />
<Control Type="7bit" Number="34" Name="Breath Control LSB" />
<Control Type="7bit" Number="35" Name="" />
<Control Type="7bit" Number="36" Name="Foot Control LSB" />
<Control Type="7bit" Number="37" Name="Portamento Time LSB" />
<Control Type="7bit" Number="38" Name="Data Entry LSB" />
<Control Type="7bit" Number="39" Name="Volume LSB" />
<Control Type="7bit" Number="40" Name="Balance LSB" />
<Control Type="7bit" Number="41" Name="" />
<Control Type="7bit" Number="42" Name="Pan LSB" />
<Control Type="7bit" Number="43" Name="Expression LSB" />
<Control Type="7bit" Number="44" Name="" />
<Control Type="7bit" Number="45" Name="" />
<Control Type="7bit" Number="46" Name="" />
<Control Type="7bit" Number="47" Name="" />
<Control Type="7bit" Number="48" Name="" />
<Control Type="7bit" Number="49" Name="" />
<Control Type="7bit" Number="50" Name="" />
<Control Type="7bit" Number="51" Name="" />
<Control Type="7bit" Number="52" Name="" />
<Control Type="7bit" Number="53" Name="" />
<Control Type="7bit" Number="54" Name="" />
<Control Type="7bit" Number="55" Name="" />
<Control Type="7bit" Number="56" Name="" />
<Control Type="7bit" Number="57" Name="" />
<Control Type="7bit" Number="58" Name="" />
<Control Type="7bit" Number="59" Name="" />
<Control Type="7bit" Number="60" Name="" />
<Control Type="7bit" Number="61" Name="" />
<Control Type="7bit" Number="62" Name="" />
<Control Type="7bit" Number="63" Name="" />
<Control Type="7bit" Number="64" Name="Sustain Pedal" />
<Control Type="7bit" Number="65" Name="Portamento Pedal" />
<Control Type="7bit" Number="66" Name="Sostenuto Pedal" />
<Control Type="7bit" Number="67" Name="Soft Pedal" />
<Control Type="7bit" Number="68" Name="" />
<Control Type="7bit" Number="69" Name="Hold Pedal" />
<Control Type="7bit" Number="70" Name="" />
<Control Type="7bit" Number="71" Name="" />
<Control Type="7bit" Number="72" Name="" />
<Control Type="7bit" Number="73" Name="" />
<Control Type="7bit" Number="74" Name="" />
<Control Type="7bit" Number="75" Name="" />
<Control Type="7bit" Number="76" Name="" />
<Control Type="7bit" Number="77" Name="" />
<Control Type="7bit" Number="78" Name="" />
<Control Type="7bit" Number="79" Name="" />
<Control Type="7bit" Number="80" Name="" />
<Control Type="7bit" Number="81" Name="" />
<Control Type="7bit" Number="82" Name="" />
<Control Type="7bit" Number="83" Name="" />
<Control Type="7bit" Number="84" Name="" />
<Control Type="7bit" Number="85" Name="" />
<Control Type="7bit" Number="86" Name="" />
<Control Type="7bit" Number="87" Name="" />
<Control Type="7bit" Number="88" Name="" />
<Control Type="7bit" Number="89" Name="" />
<Control Type="7bit" Number="90" Name="" />
<Control Type="7bit" Number="91" Name="Effects Depth" />
<Control Type="7bit" Number="92" Name="Tremolo Depth" />
<Control Type="7bit" Number="93" Name="Chorus Depth" />
<Control Type="7bit" Number="94" Name="Celeste Depth" />
<Control Type="7bit" Number="95" Name="Phaser Depth" />
<Control Type="7bit" Number="96" Name="Data Increment" />
<Control Type="7bit" Number="97" Name="Data Decrement" />
<Control Type="7bit" Number="98" Name="NR Parameter LSB" />
<Control Type="7bit" Number="99" Name="NR Parameter MSB" />
<Control Type="7bit" Number="100" Name="Reg Parameter LSB" />
<Control Type="7bit" Number="101" Name="Reg Parameter MSB" />
<Control Type="7bit" Number="102" Name="" />
<Control Type="7bit" Number="103" Name="" />
<Control Type="7bit" Number="104" Name="" />
<Control Type="7bit" Number="105" Name="" />
<Control Type="7bit" Number="106" Name="" />
<Control Type="7bit" Number="107" Name="" />
<Control Type="7bit" Number="108" Name="" />
<Control Type="7bit" Number="109" Name="" />
<Control Type="7bit" Number="110" Name="" />
<Control Type="7bit" Number="111" Name="" />
<Control Type="7bit" Number="112" Name="" />
<Control Type="7bit" Number="113" Name="" />
<Control Type="7bit" Number="114" Name="" />
<Control Type="7bit" Number="115" Name="" />
<Control Type="7bit" Number="116" Name="" />
<Control Type="7bit" Number="117" Name="" />
<Control Type="7bit" Number="118" Name="" />
<Control Type="7bit" Number="119" Name="" />
<Control Type="7bit" Number="120" Name="" />
<Control Type="7bit" Number="121" Name="Reset All" />
<Control Type="7bit" Number="122" Name="Local Control" />
<Control Type="7bit" Number="123" Name="All Notes Off" />
<Control Type="7bit" Number="124" Name="Omni Off" />
<Control Type="7bit" Number="125" Name="Omni On" />
<Control Type="7bit" Number="126" Name="Mono On" />
<Control Type="7bit" Number="127" Name="Poly On" />
</ControlNameList>
</StandardDeviceMode>
</MIDINameDocument>
_________________
iMac G5 2 ghz 2 gigs RAM OS X.3.9, MOTU 828mkII , Apogee Big Ben, Dp 4.5.2, Mach 5, MX4, Battery2.1, NI Pro 53, Cameleon 5000, EastWest Gold Orch w/Kompakt, Absynth 3, Atmosphere, Stylus RMX, Arturia Moog Modular V, Altiverb, Autotune, Stormdrum
Thank you a billion times over. I tried doing something similar a few times, but I must have something wrong .
richard
wow- I'm glad it worked! I was doubtful that it'd actually work- cool!
-Frank
PS- Happy New Year
<MIDINameDocument>
<PatchNameList>
</PatchNameList>
</PatchBank>
</ChannelNameSet>
</NoteNameList>
</ControlNameList>
</MIDINameDocument>
_________________
richard
Re: Here's some additional info that might be relevant to yo
This is super-cool, but there's one thing it's missing: drum note names.greeny wrote:Here's a text I lifted off from some forum (I can't temember which) that can help one put actual names to these patch numbers - GM names that is. And, I've done it myself and it works!
Turns out you can use this same trick to give the DLSSynth (and other VIs) note names in the DrumEditor, which in my opinion is a hugely cool twist on this.
I found it much easier to just use an edited version of the "General MIDI.midnam" file, instead of using the one pasted above (which does not include note names for the GM kit). Here are the steps I used:
- archive off your old "Default Names.midnam" file somewhere else, and then trash that file
- duplicate "General MIDI.midnam", and rename the _duplicate_ as "Default Names.midnam"
- open this "Default Names.midnam" file in a text editor (preferrably a real text editor like BBEdit, or perhaps even TextEdit.app)
- change the line that reads:
<StandardDeviceMode Name="General MIDI" >
to:
- save
That's it, and now next time you launch DP you'll not only have all the GM patches for the DLSSynth, but you'll have note names in the DE. You need to set the track in question to channel 10 (which you'd have to do anyways), and select the "Standard Kit" patch for the track, and then you're good to go.
Concerning DLS
You could try this one and all your instruments will be separated in banks (pianos basses, guitars, etc.)
As for the reverb, you can tweak all your settings in the DLS window.Ã
Tell me if it doesn't work and I'll send the .midnam file to you via Email
<MIDINameDocument>
<ChannelNameSetAssign Channel="10" NameSet="Name Set 2" />
<AvailableChannel Channel="10" Available="false" />
<PatchBank Name="Piano" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Chromatic Percussion" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Organ" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Guitar" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Bass" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Strings/Orchestra" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Ensemble" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Brass" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Reed" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Pipe" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Synth Lead" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Synth Pad" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Synth FX" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Ethnic" >
<PatchNameList>
<Patch Number="112" Name="Shanai" ProgramChange="111" />
</PatchNameList>
</PatchBank>
<PatchBank Name="Percussive" >
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchBank Name="Sound FX" >
<PatchNameList>
</PatchNameList>
</PatchBank>
</ChannelNameSet>
<ChannelNameSet Name="Name Set 2" >
<AvailableChannel Channel="1" Available="false" />
<AvailableChannel Channel="2" Available="false" />
<AvailableChannel Channel="3" Available="false" />
<AvailableChannel Channel="4" Available="false" />
<AvailableChannel Channel="5" Available="false" />
<AvailableChannel Channel="6" Available="false" />
<AvailableChannel Channel="7" Available="false" />
<AvailableChannel Channel="8" Available="false" />
<AvailableChannel Channel="9" Available="false" />
<AvailableChannel Channel="11" Available="false" />
<AvailableChannel Channel="12" Available="false" />
<AvailableChannel Channel="13" Available="false" />
<AvailableChannel Channel="14" Available="false" />
<AvailableChannel Channel="15" Available="false" />
<AvailableChannel Channel="16" Available="false" />
<PatchBank Name="Drum Kits" >
<PatchNameList>
<Patch Number="001" Name="Standard Kit" ProgramChange="0" >
<UsesNoteNameList Name="Drum Sounds" />
</Patch>
</PatchNameList>
</PatchBank>
</ChannelNameSet>
<NoteNameList Name="Drum Sounds" >
<Note Number="35" Name="Acoustic Bass Drum" />
<Note Number="36" Name="Bass Drum 1" />
<Note Number="37" Name="Side Stick" />
<Note Number="38" Name="Snare 1" />
<Note Number="39" Name="Hand Clap" />
<Note Number="40" Name="Snare 2" />
<Note Number="41" Name="Low Floor Tom" />
<Note Number="42" Name="Closed Hi Hat" />
<Note Number="43" Name="High Floor Tom" />
<Note Number="44" Name="Pedal Hi-Hat" />
<Note Number="45" Name="Low Tom" />
<Note Number="46" Name="Open Hi-Hat" />
<Note Number="47" Name="Low-Mid Tom" />
<Note Number="48" Name="Hi-Mid Tom" />
<Note Number="49" Name="Crash Cymbal 1" />
<Note Number="50" Name="High Tom" />
<Note Number="51" Name="Ride Cymbal 1" />
<Note Number="52" Name="Chinese Cymbal" />
<Note Number="53" Name="Ride Bell" />
<Note Number="54" Name="Tambourine" />
<Note Number="55" Name="Splash Cymbal" />
<Note Number="56" Name="Cowbell" />
<Note Number="57" Name="Crash Cymbal 2" />
<Note Number="58" Name="Vibraslap" />
<Note Number="59" Name="Ride Cymbal 2" />
<Note Number="60" Name="Hi Bongo" />
<Note Number="61" Name="Low Bongo" />
<Note Number="62" Name="Mute Hi Conga" />
<Note Number="63" Name="Open Hi Conga" />
<Note Number="64" Name="Low Conga" />
<Note Number="65" Name="High Timbale" />
<Note Number="66" Name="Low Timbale" />
<Note Number="67" Name="High Agogo" />
<Note Number="68" Name="Low Agogo" />
<Note Number="69" Name="Cabasa" />
<Note Number="70" Name="Maracas" />
<Note Number="71" Name="Short Whistle" />
<Note Number="72" Name="Long Whistle" />
<Note Number="73" Name="Short Guiro" />
<Note Number="74" Name="Long Guiro" />
<Note Number="75" Name="Claves" />
<Note Number="76" Name="Hi Wood Block" />
<Note Number="77" Name="Low Wood Block" />
<Note Number="78" Name="Mute Cuica" />
<Note Number="79" Name="Open Cuica" />
<Note Number="80" Name="Mute Triangle" />
<Note Number="81" Name="Open Triangle" />
</NoteNameList>
<Control Type="7bit" Number="64" Name="Sustain 0Off 127On" />
<Control Type="7bit" Number="65" Name="Portamento 0Off 127On" />
<Control Type="7bit" Number="66" Name="Sostenuto 0Off 127On" />
<Control Type="7bit" Number="67" Name="Soft 0Off 127On" />
<Control Type="7bit" Number="69" Name="Hold2 0Off 127On" />
<Control Type="7bit" Number="84" Name="Portamento Time LSB" />
<Control Type="7bit" Number="98" Name="N-Reg Parameter LSB" />
<Control Type="7bit" Number="99" Name="N-Reg Parameter MSB" />
<Control Type="7bit" Number="120" Name="All Sound Off" />
<Control Type="7bit" Number="122" Name="Local Control 0Off 127On" />
<Control Type="7bit" Number="126" Name="Monophonic On" />
<Control Type="7bit" Number="127" Name="Polyphonic On" />
</ControlNameList>
</MIDINameDocument>
<MIDINameDocument>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
<PatchNameList>
</PatchNameList>
</PatchBank>
</ChannelNameSet>
<PatchNameList>
</Patch>
</PatchNameList>
</PatchBank>
</ChannelNameSet>
</NoteNameList>
</ControlNameList>
</MIDINameDocument>
