setting recording levels DP
chancellor
Post by chancellor »
Is there a way to adjust the incoming recording level in D.P.? Not just the monitor level, but the actual recording level? I've been pouring over the manual, and I cannot figure this out. I'm coming in from the line input from the 828mkII.
Thx,
Ken
builder
Post by builder »
Turn the source down.....
DP just records what you put in it.
Music - http://www.missingpalmerwest.com/Missin ... songs.html
Dual 2.0 G5 (Rev. A), 4.5 GB Ram, Powerbook 1.5 GHZ 1.5 GB Ram, (BLA) 828mkII, UAD-1 X2 , 10.4.8, DP 5.13, Sebatron VMP2000e, Sytek MPA, Many Mics
Newsles
Post by Newsles »
Well, there ARE other things you can do to be fair!
For a start, if your source is running too hot (OK you COULD turn it down at source, but assuming this isnt possible for some reason), then sending via an aux with the Trim plug-in, and then to a voice track, would be one option. Although it provides gain, it can of course be used to turn an input source down, AND it's metering is very accurate (im told!).
If it's a case of transients causing clipping then a small amount of limiting (with a limiter plug-in on the aux instead) could help that.
Just a thought!
To be honest tho, I find most of my levels need boosting not cutting for some reason. Ive checked my overall outboard gain structure and made adjustments but there's so much headroom on digital systems (to which Im fairly new to be honest) that they mostly need a boost.
I could normalise all my soundbites after recording but I dont think that should have to be the long-term solution.
Anyway, slight divergance on the topic here, but that's my input (no pun intended :roll: )
I refer the Honourable Gentleman to the anwser I gave a moment ago...G4-upgraded G3, DP2.72, Korg 1212 card, Fostex 8-channel AD/DA converter, Korg DW8000, Novation Basstation, Kork M1rEX, Vintage Keys Plus, Akai S2000, Transcendent 2000 monosynth, Presonus ACP8 8-channel comp/gate, Behringer Multicom, Zoom and Yamaha external FX and a few other bits and pieces!
builder
Post by builder »
I shouldn't have to say this, but once you clip the signal BEFORE your converters your done, the wave has already been cut off. The trim plug will do nothing but lower the clipped signal.
I use a Sytek preamp a lot for drums, which doesn't have a Pad Attenator on it. Depending on the mic I use, sometimes the singal is too hot even with the gain all the way done. So I bought some Shure -20db line pads to put in between the output of the preamp and the input of my 828mkii. This helps tame the souce before it hits the converts.
Again, turn down your source.
PS. Do a search on Normalizing, you might change your mind.
Newsles
Post by Newsles »
Point taken Builder - if it's clipping then of course, but if it's just a case of using bags of the digital headroom and you want a bit more of a reasonable level then Trim WOULD do the job of course.
Cheers
builder
Post by builder »
I guess my point is if it is already in DP, recording through an aux into the Trim plug in would be the same as recoding the signal, then bouncing it with the plugin inserted.
Jim
Re: setting recording levels DP
Post by Jim »
chancellor wrote:Is there a way to adjust the incoming recording level in D.P.? Not just the monitor level, but the actual recording level? I've been pouring over the manual, and I cannot figure this out. I'm coming in from the line input from the 828mkII.
Thx,
Ken
Either control level from the instrument itself, or insert a mixer, compressor, limiter or preamp, etc. between the instrument and the interface.
giles117
Post by giles117 »
builder wrote:I guess my point is if it is already in DP, recording through an aux into the Trim plug in would be the same as recoding the signal, then bouncing it with the plugin inserted.
Of course this would be purposeless if the signal was already clipped upon the original recording process.
DP 6.02
Quad 3.0 Ghz, 8.0 GB RAM, 2 - 1TB HD, 5 - 500GB HD's (RAID)
MOTU HD192, 2408mk3, Microlite, UAD-1, UAD-2, Powercore, Lavry Blue AD/DA convertor, LA-610
Euphonix MC Control
29 years in this business and counting.....Loving every minute of it.....
builder
Post by builder »
Exactly......
Newsles
Post by Newsles »
I agree with the above, but as I said, as long as it's not clipping and causing digital distortion then it would work. Sorry if Ive confused matters!!! :(
