Hello,
I've been having issues (popping, etc.), some but not all of which are fixable with higher buffer settings. Seems to be more of an issue with the more tracks I am running with pitch correction. As for "printing" these tracks using merge, I haven't had success with that (seems straightforward enough...).
I haven't been able to find out the following: are there different system requirements for 4.6, now that it has the pitch correction? I know my 800 Mhz single processor, 768 MB RAM is fine for DP 4.
It is truly a wonderful feature and so well implemented.
Thanks in advance for any help and a very helpful forum.
Gerhard
System requirements for 4.6 & pitch correction?
I've sort of been through this thing too. I would recommend going into DP preferences and turning off any Beat Detention stuff that you can find, as well as turning off the pitch correction until you need it. This helped me greatly as far as the pops and CPU spikes. I have used the pitch correction with some success, but I leave it off until I need it.
I'm running a 1g single processor laptop with an external hard drive.
