EWQLSO Gold w/DP 4.6 newbie questions
I need some serious help with this stuff.
I'm able to record and playback on MIDI tracks fine.
1. Can I record direct to audio tracks or maybe convert the MIDI tracks to audio tracks? If so, how? I can't figure it out.
2. I can't pan the MIDI tracks. Either in Kompakt or DP. As a matter of fact, when I pan hard right there is no sound at all but the meter in Kompact shows the signal and is being panned. My DP in and outputs or "on" within the MIDI preferences of Kompakt. I've tried drawing a pan line with the pencil tool on a track in DP but did'nt work. I can't figure it out.
I have more questions but I'll just leave it at these for now.
- richard
Sorry to not go into more detail....
1. Look up freeze tracks in the manual. You can also record direct to audio if you have the inputs for the audio track be the VI....
2. You might have a studio issue....if everything looks correct when panned (meters moving in the correct way), but you're not getting a signal through your monitors, you'll have to follow the signal path and find where the audio is being stopped.
Best of luck!
Rich
Best of luck!
Rich
Richard Temple
G5 2x2 4.5Gb, MacBook, 828mkII, Tascam FW 1804, DP, Logic, Giga, MachV, Reason, Live, EW Gold, Stormdrums, Atmosphere....
www.mutexmusic.com
www.mutexmusic.com
Thanks for the reply Richard. You were right about #2. I'm able to pan the MIDI now.
I assigned the input of an audio track in DP to "EWQLSO gold edition 2 3-4" but no audio was recorded and no meters in audio monitor.
I was able to freeze tracks once but again no audio in freeze track.
For some reason the freeze option is never highlighted when I select tracks or parts of tracks (except that once.)
I had sim. problem, try...Make sure the audio patch thru symbol is active by clicking on the little pair of headphones on the main window frame in the top left corner.
2x2.66 GHz Mac Pro Dual-Core Intel Xeon w/ 5GB RAM, MacBook 2.4 GHz Core 2 Duo w/4GB RAM. DP 5.13, East West Platinum ProXP, East West PLAY (Goliath, SD2) BFD, Spectrasonics Atmosphere + Trilogy, Stylus RMX, Kontakt 2, Ethno instr. and MSI.
