G4 MDD 1.42 DP 2GB RAM or G5 SP 1.8 1GB RAM
nelsonvisions
Post by nelsonvisions »
just curious for the same money more or less, what the better machine would be. I use 4.5, Sampletank 2 and SonikSynth 2, Presonus Firepod, I just want to be able to record 8 mics at once with no firewire 400 slowdown and click/pop! I can't quite do it with my pismo g4 550.
builder
Post by builder »
Either will do want you want. I would probably go for the G5. Its newer and
167MHZ buss vs 900MHZ-1GHZ (depending on the model) is a pretty big factor.
Your best bet is to find the DP 1.8 G5 in can't be that much more
Music - http://www.missingpalmerwest.com/Missin ... songs.html
Dual 2.0 G5 (Rev. A), 4.5 GB Ram, Powerbook 1.5 GHZ 1.5 GB Ram, (BLA) 828mkII, UAD-1 X2 , 10.4.8, DP 5.13, Sebatron VMP2000e, Sytek MPA, Many Mics
