DP 4.61 with Powercore
lachr
Post by lachr »
I'm experiencing crashes with DP and Powercore. During one day I was mixing one song I experienced 7 crashes. It usually happens if I try to change buffer/studio settings, open PoCo plugins or move/copy PoCo plugins to other tracks during playback.
Now, I had all the latest drivers installed, exept the new 1.3 firewire driver for my 828.
Any other DP/Powercore users out there who experinced the same problems?
Best regards
Lars Asp
Mastering engineer
http://www.larsaspmastering.com
Denmark
System: iMac 3.6 mhz 32 gb, Apollo 16/Twin + 8xDSP system, Presonus Digimax, SPL Goldmike 9844, Joemeek VC1, Revox A77, Genelecs 1031A
rknaub
Post by rknaub »
With any DSP card, its better to stop the playback if you are changing, moving the plugs to another channel.
I have seen all kinds of problems with the TCPC when tryin to do that.
AS well if you insert a new TCPC plug while DP is playing the automatic delay compensation will not work, until you stop and start the transport again,
Just a few tips.
HTH
Randy
Randy Knaub
Jireh Productions
San Jose, CA
www.musicforthemasses.com
lachr
Solution
Post by lachr »
Well, it turns out that it probably was the 1.2.5 MOTU 828 driver. After upgrading to 1.3.0 my system seems to run smoth again. Thanks anyway...
Lars Asp
Mastering engineer
Denmark
