4.6.1 and plug-in problem
I installed 4.6.1 today from 4.5.2 and found that all my plugs including MAS did not respond - that is, I am unable to change settings, bypass, etc. I opened 4.5.2 and all plugs respond correctly. I reinstalled 4.6.1 and found the same behavior. I have an email to MOTU but wondered if anyone here has experienced this.
G5 2.5/ tiger 10.4.2/ HD 192
I had really weird things happen with my uad stuff..... projects done in before 4.61 would crash dp if any uad plug was used...
The workaround was to open those projects on my laptop, remove the uad plugin, resave and then open them on the main deck... put the plug back in, save and all is well.....
Still scratching my head...
mi
mi
Plug in Problems
I upgraded to 4.6.1 and I have the TCElectronic powercore element. Whenever I load a TC plug in, I crash. I got clients breathing down my neck. Looking with you...
Powercore crash
I use DP 4.6.1 and have experienced 5 crashes today while mixing a song with powercore plugins. It usually happens while I open TC plugins during playback, try to change buffer setting and if my powercore element card is filled up. I highly suspect TC for being the problem...
Lars Asp
Mastering engineer
http://www.larsaspmastering.com
Denmark
System: iMac 3.6 mhz 32 gb, Apollo 16/Twin + 8xDSP system, Presonus Digimax, SPL Goldmike 9844, Joemeek VC1, Revox A77, Genelecs 1031A
Mastering engineer
Denmark
FWIW when I installed 4.61 all my UAD and TC stuff went weird. Multiple crashes and problems for the first day.
After shutting down everything and restarting about 4 times suddenly everything worked fine. I'm not sure what it was all about or how it sorted itself out but it's been rock-solid since then.
