Does DP work with non-MOTU hardware?
EddieRivas
Post by EddieRivas »
For example will a Firepod work with DP?
Eddie
Power Mac 2.66 dual core
10GB RAM
MOTU 24io
Protools 10
sdfalk
Post by sdfalk »
Anything with coreaudio/proprietary drivers for OSX works with DP.
So yes.
I thought this would be obvious by now.
A Metric Halo ULN8-3D…mmmmmmm
EddieRivas
sdfalk wrote:Anything with coreaudio/proprietary drivers for OSX works with DP.
So yes.
Well, since I'm blind I can't necessarily read up on all the info out there.
thanks.
10GB RAM
MOTU 24io
Protools 10
billf
Re: Does DP work with non-MOTU hardware?
Post by billf »
EddieRivas wrote:For example will a Firepod work with DP?
Eddie
Eddie,
Is the FirePod is CoreAudio capable? If so, then you should be good to go. Check the config in the Audio/MIDI setup utility, and DP should be able to find it.
giles117
Post by giles117 »
EddieRivas wrote:
Well, since I'm blind...
So hows that working out for you?
DP 6.02
Quad 3.0 Ghz, 8.0 GB RAM, 2 - 1TB HD, 5 - 500GB HD's (RAID)
MOTU HD192, 2408mk3, Microlite, UAD-1, UAD-2, Powercore, Lavry Blue AD/DA convertor, LA-610
Euphonix MC Control
29 years in this business and counting.....Loving every minute of it.....
giles117
Post by giles117 »
Oh yeah, just wanted to add some info fromMOTU's site....
No audio production software provides better support for Macintosh OS X Core Audio and Core MIDI services. Built from the ground up for Mac users, Digital Performer takes full advantage of sample-accurate MIDI Time Stamping, Core MIDI patch list support, Audio Unit plug-ins and virtual instruments, support for multiple Core Audio interface drivers and more.
Digital Performer has full support for Apple Core MIDI and Core Audio protocols, and includes patch lists and expansion bank support for most available synths. Digital Performer supports multiple Core Audio drivers the latest Apple Audio Unit standard for plug-ins and virtual instruments. Use any MIDI or audio interface supported by Apple OS X.
Lasik......
DP 6.02
Euphonix MC Control
sdfalk
Post by sdfalk »
So yes.
thanks.
