DP 4.5 and BFD RTAS
DP 4.5 and BFD RTAS
Is anyone using BFD in RTAS??
Does it work!!
Does it work!!
Re: DP 4.5 and BFD RTAS
If you're using BFD in Digital Performer, you have to use AU, not RTAS. RTAS is for ProTools
Actually RTAS is supposed to work in DP 4.5. However...it's still a bit buggy. My RTAS plugins seem to all work. RTAS instruments are another matter. It seems to me I read earlier that BFD under RTAS has display and delay problems (I don't use it myself). Stylus RMX definately has problems. Lounge Lizard works properly but there are interface display problems. The old version of Stylus seems to work properly. Hopefully MOTU will fix things soon.
DP8.04, Mac Pro 2 x 3.2GHz Quad Core running 10.6.8, 16GB RAM, Pro Tools HD5 with four 192 interfaces,VEP Pro 5 running on custom built PC/Windows 7, Vienna Instrument Pro, 2 x MOTU Travellers, UAD Apollo Quad, Waves 9, Slate Digital, Sound Toys, Spectrasonics Stylus, Omnisphere, Trillian, Ivory, Lounge Lizard, Kontact 5, Guitar Rig, LASS strings, Symphobia 1 & 2, Control 24, 2 x Artist Mix and 1 x Artist Control, Yamaha Disklavier Pro plus too many other VIs and plugins to list
Yes... we can hope they fix it soon.
But it's May now and BFD still is a RTAS no-go in DP.
Is there a way to get individual outs from BFD with DP?
Thanks in advance for any advice you can offer...
- toodamnhip
I run BFD in multi out mode using re-wire and VST I believe..I will check next time and be more specific
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- daveyboy
How can you use rtas plugs in DP??? They don't show up for me and I have a ton of them. Love to hear how to do it...
<small>[ May 19, 2005, 11:24 AM: Message edited by: daveyboy ]</small>
Dave
www.dbwproductions.com
You have to run DP under DAE rather than MAS. If you have Pro Tools hardware (i.e. interfaces and cards) there should be no problem.Originally posted by daveyboy:
- daveyboy
I'm assuminig ths is only with "real" pro tools ( I have the digi 002r), correct?Originally posted by Modular:
Dave
I don't know-I'm on an HD Accel system. It seems to me that if the Digi 002r uses DAE and can access RTAS plugins then it should work in DP. Make sure that your audio system is running under DAE, the voice assignment for your audio track is set to automatic and that the RTAS plugin is not inserted after any non-RTAS plugin. If you can't make it fly then email or call MOTU tech support .Originally posted by daveyboy:
So is it possible to use Rewire to get all outputs individually from BFD?
When I set up DP and BFD as a rewire client (All Outs)... I can get BFD to show up on an Aux... but NOT on an audio input track. The manual says it's a doable thing... I must be missing something.
Any advice on how to get BFD individual outs to appear?
I'm sure it's something bonehead that I'm missing.
- daddyunicorn
The only Digi hardware that use DAE under DP are HD systems. oo2r , mbox all run under MAS.
Dual G5 2.0 (pre-intel), 2408iii, DA7, WR-AD96, c1's, api312's, 10.4.10, DP 5.12, mach 5, Waves Gold., pc88, 2080, Reason 3, logic 8pro, Antares AutoTune, red lava lamp
I use BFD in MAS with Rewire. I have an HD system
but I run it through CoreAudio to monitor. After I freeze my BFD, Reason and Mach5 tracks I export as OMF
and import into ProTools. This way I get multiple outs
from everything! DP 4.52 still doesn't seem to work very well with DAE anyway. i then track and mix in ProTools. It's creamy groove love pony smokin' monkey jam. ©2005 Little Webb Music
