Waves GUI
nyplugin
Waves GUI
Post by nyplugin »
I've just noticed that some Waves GUI are laggy and slow; strangely enough not all plugins, for example C1 is working good while API2500 and RComp meters are almost frozen. What can it be?
The problem is not from Waves I guess as the same plugins work well on Logic.
I run DP11.32 on a MacBook Pro M1 Max, Sonoma 14.6.1
MacOS 15 Sonoma - DP 11 - Mac Mini 2018 i7 2.3GHz - 64GB RAM
Re: Waves GUI
This is an 11.32-related issue; MOTU and Waves have reproduced.
Until resolved, the solution is to check the "Run in Real Time When Plugin Window is Open"(or similar verbiage) on one instance of the plug in (plugin mini-menu).This will apply the behavior to all instances of the particular plugin. Only downside is occasional pop or noise when opening and closing one of these plugins while DP is running.
HC Markus
M1 Mac Studio Ultra • 64GB RAM • 828es • macOS 15.4.1 • DP 11.34
https://rbohemia.com
nyplugin
Re: Waves GUI
Post by nyplugin »
Ok, thank you very much
