Dragging MIDI Notes Up and Down -FIXED DP11.32
Aaron Guidry
Post by Aaron Guidry »
:surrender: When dragging MIDI notes in the MIDI editor long distances, DP is placing the MIDI note much lower than the desired target.
For example, if I want to drag a MIDI note up from C1 to C6, I can grab the C1, scroll up to C6, release my mouse button, and the note drops down to a random note, such as an F4. Dragging MIDI notes short distances, say C1 to C2 works just fine. What's up with going the distance?
DP 11.31, Mac Studio M2 Ultra, 128GB Memory, Sonoma 14.3.1
Re: Dragging MIDI Notes Up and Down
I am experiencing similar issues in the SE. Tech note submitted to MOTU.
This video shows the problem:
https://cdn-data.motu.com/django_prod/t ... n%20SE.mov
In Sequence Editor Window, attempt to drag a MIDI Note to a new pitch beyond the frame of the visible pitches. Irregular results... sometimes it works properly and the note is moved to the intended pitch when the drag is stopped and mouse released. More often, the note either reverts back to the original pitch or, maddeningly, decides to adopt a new pitch somewhere between the original and intended pitches.
Problem seems consistent if a note is dragged beyond intended pitch (outside visible area), then back toward intended pitch. Fails every time for me.
Workaround is to reduce vertical size of notes displayed so all fit within the visible pitch area. As long as pitches are dragged within the visible area, all is well. Just don't try to drag to a pitch outside of the visible pitches,
HC Markus
https://rbohemia.com
Aaron Guidry
Keep me posted. This bug is driving me crazy!!
Looks like MOTU must know about this one now since the video is actually hosted on their site?
Don't know how long it's been going on but expanding the window/shrinking the field to show a larger area has been my workaround for awhile.
James Steele wrote: Sun Apr 14, 2024 10:38 am Looks like MOTU must know about this one now since the video is actually hosted on their site?
I just linked from my Support Ticket at MOTU.com, which I posted Friday and has yet to be reviewed.
Aaron Guidry wrote: Sun Apr 14, 2024 10:29 am Keep me posted. This bug is driving me crazy!!
It is a bother, for sure. You might want to submit a Support Ticket, too. Make that wheel squeak a little louder.
HCMarkus wrote: Sun Apr 14, 2024 12:59 pm
MOTU is logging as a bug.
Michael Canavan
Post by Michael Canavan »
I mostly use the key commands for this so It was unnoticed. Great they're logging it.
This is fixed in DP11.32
HC Markus
HCMarkus wrote: Wed Jun 05, 2024 11:48 am This is fixed in DP11.32
I had to turn part of a piano part into a celeste and dragged it up two octaves this morning. Yes!
