How much Memory to really boost the cpu?
seanplaysdrums
Post by seanplaysdrums »
I am not getting the best performance that I wish I could out of my dual 2ghz g5. I allready have 3.5gigs of ram and just installed a seperate hard drive for audio.
Would installing more ram help the cpu? When I open activity monitor it still says I have plenty of ram left. I want to be able to run a few VI's with out the
cpu meter maxing out. thanks
chrispick
Post by chrispick »
You have plenty of RAM. I can't imagine that's negatively impacting what you want.
To consider (if you haven't already):
Higher buffer settings will avail you more CPU power. The trade-off will be greater latency when playing VI. Usually, I begin tracking VIs at a 256 buffer setting. Once the CPU meter starts to hover close to red, I switch to 512. I find that 512 is often offers a workable compromise between proc strain and latency.
To note: Some VIs simply require a lot of CPU power to do their thing. For example, a soft synth that runs with a lot of changing filters, delays and what-not often needs more CPU attention than a soft sampler simply playing back sampled notes.
Also, decreasing polyphony on your VIs can help. The fewer voices they have to generate, the lesser the strain on the CPU. I often find that polyphonies are preset to be higher than I need. For instance, if I'm only playing a melody line on a VI, I don't need 32 voices to do it; often, I can cut that in half.
Don't know if this helps. Hope it does.
