Problems loading with DP11
Hello, I just upgraded to DP11/Mojave and am having problems transitioning between the two segments. When you reach the end of the segment, do not continue downloading the next segment. Has anyone had the same problem as me and solved it successfully? When using the older version, everything runs smoothly.
Re: Problems loading with DP11
Can you explain the question a little bit better. What do you mean by "segments?"oscarramirez wrote: ↑Wed Sep 13, 2023 6:57 pm Hello, I just upgraded to DP11/Mojave and am having problems transitioning between the two segments. When you reach the end of the segment, do not continue downloading the next segment. Has anyone had the same problem as me and solved it successfully? When using the older version, everything runs smoothly.
No idea what you are talking about. The Windows version downloads in parts but not the Mac version. Make certain that you are downloading DP 11.22.oscarramirez wrote: ↑Wed Sep 13, 2023 6:57 pm Hello, I just upgraded to DP11/Mojave and am having problems transitioning between the two segments. When you reach the end of the segment, do not continue downloading the next segment. Has anyone had the same problem as me and solved it successfully? When using the older version, everything runs smoothly.
Yeah... I don't understand either. Pretty sure the download for Mac is just one big .zip file isn't it?? Which expands to one large roughly 1.7GB installer pkg??
