Autotune in ara 2 ?
Autotune in ara 2 ?
Hello everyone has anyone tried using Autotune in ara 2 ? I just don't have any sound if I used Autotune ara
Re: Autotune in ara 2 ?
Not sure all ARA plugs are supported. Are you using the VST3 version of Autotune? If not, try that. I know for Melodyne to work right in DP, MOTU says you have to use the VST3 version.Thecult wrote:Hello everyone has anyone tried using Autotune in ara 2 ? I just don't have any sound if I used Autotune ara
Thanks for the reply. I use vst3 and of course in plugin format it works well but in ara format it loads but there is just no sound on the track with ara autotune
You may need to reach out to MOTU on that one. AFAIK, MOTU was primarily focused on Melodyne when they added ARA support to DP. Not sure they tested it with other software that uses ARA.
