Hi there,
It's been a long time since I've used DP's MIDI functions.
I have a MIDI track to record in the middle of the audio tracks. I notice that the recorded MIDI notes no longer appear in my Sequense window whereas they do appear in the MIDI window and in the Tracks window.
I am using DP 11.2 (iMac 5K - Mojave)
I have never encountered this problem in the 25 years that I have used DP.
Is there something new in DP 11 that I'm missing? A preference to settle somewhere, that I have not found?
Or is it a bug?
Thanks in advance
Best regards,
Christophe - Studio SLC - France
MIDI notes in the Sequence window
Re: MIDI notes in the Sequence window
Sounds like it might be the classic View Filter issue. There’s a key command toggle that will show/hide certain data and it could be notes are not being displayed.
I found. It is the CHANNEL SELECTOR which is not activated. Quite simply, but I had never used this novelty of the Sequense Window, since I almost only do audio.
Christophe
Christophe
Glad you found the answer!
