dp with pro tools sessions
Can dp read pro tools sessions? what about pro tools reading sp sessions..i know there is a way in dp to save the sessions in omf format which i thikn pro tools can read...can anyone help me on this?
With PT,you need digitranslator to open AND to save session in OMF format.
500$ for Digi...or you install PT LE on a machine for the first time and you can try digitranslator for 1 month(enough for a one shot)
The best is to use endembed format(=audio inside omf file) and to try different settings to get it working...500$ for a buggy application must be a joke!Not for Digi.
The OMF file cannot be bigger than 2 Giga.
Good luck!
Good luck!
G5 Dual 1,8;Motu 24 I/O & 1296;Ibook G3 900;Digi 002r;UA 6176;Langevin Dual Vocal Combo;Amek 9098 dual pre;Amek 9098 compressor;Amek DMCL ;Crookwood Paintpot dual pre;UA LA4.
Do you want to have all your plug ins or just take it in to mix??
A simple way to do it is to print all your tracks from 00:00:00 until the end and the import the SD2 files directly into PT and line them up and mix. It makes it a lot easier.
Just my 2c.
Jeff
Just my 2c.
Jeff
Macpro Intel 2.66, DP5.11, Pro Tools HD, Micro express MIDI, MACH5 1.08, Waves Renn 5, Melodyne, Autotune 5, Battery 2, NI -B4II, DFH Superior...
- lampostudio
I'm with Jeff, Just import the audio files into DP. The only thing is all the files have to start at 00:00:00
If any of the tracks are edited or punched you will have to line them up manually, which can be a real pain.
To import just open a new project in DP with the correct number of mono & stereo tracks. Grab a audio file and drag & drop into a mono/stereo track in DP.
This is why everything must start at 00:00:00. If you have say a bass track with 5 edits they will all want to start at 00:00:00 until you arrange them in the correct order on the bass track.
Al C
Al C
Have any of you tried AAF as opposed to OMF for sharing files between Pro Tools and DP? I haven't done an extensive test to see if AAF can retain more info, but I'd be interested to see if anyone else has. I've been a bit disappointed with how little info OMF translation retains.
By the way, DigiTranslator IS expensive, and yeah, it's a drag that they charge for it, but you know what, transferring hundreds of little files and spotting them into a timeline (going either to or from DP) is an enormous pain. I've done it. I can't tell you how long it took me! If you're transferring files that have extensive edits, or plan to do it frequently, it might be a worthwhile investment.
