recording session over network
Popfactory
Post by Popfactory »
Hi all
I've got two g4 with dp4.6 in two different rooms about 30 meters distance
Is it possible to run a recording session over a local network.
How do I implement this? What else will I need?
Is it possible to do it in real time? What about latency?
Please tell me about.
many thanks
Joe
supersonic
Post by supersonic »
The only network solution that I know of is the wormhole plug in that works well enough in mixing conditions as DP 4.6 automatically compensates the delay induced during the process of sending signal from one computer to the other for processing and then back to DP in the main mixing Mac. But this would not work in real time monitoring.
Music is movement in silence
Timeline
Post by Timeline »
Explain what is to be recorded in each room.
If over ethernet, you can control a second computer with Apples Remote Desktop but it's only remote control and one audio, no multitrack audio. I understand MIDI can also be added to the connection too.
Why two rooms?
Popfactory
Thanks for answer
In one room there are a little studio. The other is a liveroom where a band is practicising. I don't want to spent a lot of money to connect these rooms ba multicore, so I had the idea to do it over a net solution. At the end I need to have all the recorded tracks on the mac in Room 1. The idea is to leave all the recording installations, mics & monitoring, for a fast recording possability. Power on and record.
It should be fine if I can use the Mac in room2 by remote. I will try it over ethernet. I think I have to do also a monitoring line.
Many thanks
Joe
Dragonwind
Post by Dragonwind »
What about using Apple's AUnetsend and AUnetreceive that are part of Tiger?
Chris
https://www.christophercaouette.com
dp11, LP, C12, Nuendo 11, OS 12 latest version, MacPro 6,1 12 Core, 64gb RAM
pcm
Post by pcm »
Have you looked into Frontier Design's Tranzport? It give you wireless control of DP for $199. I have it, it works as advertised.
schwarz
Post by schwarz »
Dragonwind wrote:What about using Apple's AUnetsend and AUnetreceive that are part of Tiger?
Chris
I think AUnetreceive won't work with DP.
Studio Setup: G4 1.25, 24 i/o 10.4, Analog Console
Live Setup: PB 12", 867
supersonic
If you don't need to monitor back the signal that's being monitored than wormhole should do fine. I'll do some tests this week to see if there are any synchro problems between each track.
remmurd
Post by remmurd »
I second the Frontier Design TranZport!
Been one of my best purchases for recording.(besides the Avalon, of course...)
Do you want the audio recorded into the "Room A" Mac? Or the "Room B" Mac?
And are you saying that the rehearsal room is "Room B"?
The Tranzport will give you the ability to control either Mac with DP with the ablity to arm tracks for recording, Solo,Mute, Punch, etc...
here's a link:
http://frontierdesign.com/Products/TranzPort
Take a look. Might be the way to go.
Do what you love, love what you do.
remmurd
Post by remmurd »
