Connecting iPhone to Mac Pro issue
RROY
Post by RROY »
I remember sometime ago that physically connecting your iPhone to a Mac could hose Motu plugins. Is this still a problem or have updates corrected this? One other question. Does the firmware update update for High Sierra negate going back to Sierra? I know I'm a bit behind the times.
Thanks kindly
Mac Pro 2x2.4 quad core /24 gb ram/OS 10.13.6, Dp 10.13, MTP AV, /UAD 2, KOMPLETE 12, Stylus RMX, SD 3.0, EZ Drummer 3, A&H ZED R 16.
RROY
Re: Connecting iPhone to Mac Pro issue
Post by RROY »
Am I the only one who remembers this problem. I have not connected my iPhone, via USB, to my MacPro since this issue occurred. Has nobody installed High Sierra with the firmware update, and booted to a Sierra OS on another drive ? Will Sierra still work after the firmware update?
Tritonemusic
Post by Tritonemusic »
RROY wrote: Sun Sep 19, 2021 5:29 am Am I the only one who remembers this problem.
I remember it. Here's a post from 2019:
viewtopic.php?t=66786&p=567301
Unfortunately, I can't help because I use Android for mobile.
DP 10.13, OS 13.7.5, iMac Pro (2017) 3.2 GHz 8-Core, 32 GB RAM, MOTU M4
It was an Apple issue that was fixed long time ago. I no longer recall the details except that most of us never had the problem.
RROY
Post by RROY »
Thanks for the replies. I don't think I will try connecting my iPhone till I upgrade to High Sierra.
artfarm1
Post by artfarm1 »
FWIW, I use my iPhone with my two Mac's that are both on OSX High Sierra. (2009 MacPro and 2015 MacBook Pro)
But, I use the 'iMazing' software pretty much anytime I need to connect my iPhone.
Check out 'iMazing'. It's excellent. Haven't had any problems in six years and over a few different laptops and OSX's.
https://imazing.com/
DP 11, OS Ventura
MacMini 2023 M2Pro, 16 gig RAM, MOTU M6, SSD drives for everything, various sound/sampled libraries from all major vendors, Logic Pro X, DSP-Quattro
MacBook Pro 2015, OSX Monterey, 2.5ghz, 16 gig RAM (w/duplicate software as in MacMini setup)
Trombones: King 2B SilverSonic, King 2B Liberty, & Conn 88H w/Doug Elliott mouthpieces!
http://www.cammillarmusic.com
It's an old iOS issue that was quickly resolved by Apple.
AlexPhilip
Post by AlexPhilip »
You should be able to do an iCloud backup over WiFi, but if you need to backup to your computer you might have to use an adapter (get used to that btw)
I think it may, at least for the initial “pairing”
https://support.apple.com/en-za/HT203075
Hopefully someone else will post something to prove me wrong.
For what it’s worth, you’re probably going to need a USB adapter at some point.
But yeah, that sucks, and it doesn’t help you right now
2025
