Hello everyone. I just upgraded my DP10 to DP11. The one thing that is blaring out at me, and perhaps I missed a setting update somewhere, is when I am overdubbing MIDI (replacing/correcting a line, etc.) and I punch out while holding a MIDI note, in versions of old, DP would insert a note off command right there at the punch-out point. Now, when I punch out, DP removes the last note and leaves a hole. So I have to manually go back and place the note in or try to release my hand on my MIDI controller before I punch out to retain the note. I then have to go back and move the release to fill in that gap. Does anyone else have this issue or a suggestion on how I can remedy this?
Thank you for all of your suggestions.
John Carter
thirteen/eight productions
Setting? Last MIDI Note on punch out is being deleted
Re: Setting? Last MIDI Note on punch out is being deleted
Sounds like a bug. You can always add a similar MIDI track record your and overdub there. Just erase the bad notes on the first track. I end up doing this sometimes because it makes it a lot easier to record replacements for the bad notes without fear of erasing the good ones.
