Recording from Amp with usb
Posted: Fri Jun 05, 2020 12:41 pm
Hello to everybody , how can I record from a Guitar Amp connected with usb? On DP10 I don't see any input from usb. Thanks
https://www.motunation.com/forum/
I thought so too, but I only see the inputs of Mic1 and Mic2, no usbmikehalloran wrote:Not nearly enough information but I'll take a stab at it.
If your amp can output audio via USB, it must be selected as an input device in DP.
So, my iMac can see my Amp ( Boss Katana ). With Garage Band I have no problem to recording. Audio/MIDI setup can see Katana. But, I have no possibility to find in the input of DP. That's allmikehalloran wrote:F that’s the case, then the amp is the issue—your Mac can’t see it.
Does it output audio via usb? Does it require drivers so your Mac can see it? Is there a switch or setting you must engage? Time to consult the manual or ask support. Is there a user group?
It needs to be seen there. If not... well it should.CharlzS wrote:Are you saying it doesn't show up in DP Setup -> Configure Audio -> Configure Hardware? You can't command-click it to add it as an additional audio device?
