Recording from Amp with usb
- dado
Hello to everybody , how can I record from a Guitar Amp connected with usb? On DP10 I don't see any input from usb. Thanks
iMac 27" 3 ghz 32 Giga ram / DP 11 / Motu UltraLite mK4/ TLAudio Ivory 5051 / Addictive Drum2 / PRS Custom22 Guitar / Boss Katana100 / Line 6 Variax700 / Strat by Tino Tedesco
Re: Recording from Amp with usb
Not nearly enough information but I'll take a stab at it.
If your amp can output audio via USB, it must be selected as an input device in DP.
- dado
I thought so too, but I only see the inputs of Mic1 and Mic2, no usbmikehalloran wrote:Not nearly enough information but I'll take a stab at it.
F that’s the case, then the amp is the issue—your Mac can’t see it.
Does it output audio via usb? Does it require drivers so your Mac can see it? Is there a switch or setting you must engage? Time to consult the manual or ask support. Is there a user group?
- daniel.sneed
What Mike said.
Just to say it in another way:
Does Audio MIDI Setup (utilities app) see your amp ?
If it does, then DP should see it.
If it does not, DP can't track from it.
dAn Shakin' all over!
Falcon, Kontakt, Ozone, RX, Unisum, Michelangelo, Sparkverb, Soundtoys
- dado
So, my iMac can see my Amp ( Boss Katana ). With Garage Band I have no problem to recording. Audio/MIDI setup can see Katana. But, I have no possibility to find in the input of DP. That's allmikehalloran wrote:F that’s the case, then the amp is the issue—your Mac can’t see it.
Are you saying it doesn't show up in DP Setup -> Configure Audio -> Configure Hardware? You can't command-click it to add it as an additional audio device?
DP 11.34 PT 2025.6 Mixbus 11 VEP 7.x with various VIs
MOTU M4 on MacBook Air M2 2023 Sequoia.5
You haven't told us where it "doesn't show up"
Since GB can see it, we know it supports 44.1kHz. If you are using a different sample rate, try that. If you want to use a different sample rate and it won't let you, that's a limitation of the amp.
It needs to be seen there. If not... well it should.CharlzS wrote:Are you saying it doesn't show up in DP Setup -> Configure Audio -> Configure Hardware? You can't command-click it to add it as an additional audio device?
