Zoom To Track?
Zoom To Track?
I hadn't noticed this before. But trying it out here, it crashes DP every time. Anyone use this successfully?
Re: Zoom To Track?
Not seeing it here.
Re: Zoom To Track?
Can you just record the Zoom session using Zoom's record function, then import to DP after the fact? I don't remember if Zoom gives you any option to record audio only.
Re: Zoom To Track?
stubbsonic wrote:Can you just record the Zoom session using Zoom's record function, then import to DP after the fact? I don't remember if Zoom gives you any option to record audio only.
I was talking about the function in DP that zooms the Sequence Editor so a track takes up the entire height.
Re: Zoom To Track?
bayswater wrote: I was talking about the function in DP that zooms the Sequence Editor so a track takes up the entire height.
How are you doing this? On the rare occasions I do it, I use the + - arrows on the right.
Re: Zoom To Track?
Sorry, I've got Zoom on the brain, apparently! :lol:
taka
Re: Zoom To Track?
Post by taka »
I have "View Selection in Sequence Editor" assigned to one of my Wacom tablet pen buttons (my main pointing device), which does the same thing as you describe, I think... It opens whatever is selected (in any window) in Sequence Editor at the size of SE window.
I've never had any crash relating to this :-)
Taka
DP11.3, OS 13.6.3, Mac Mini 2018 6 core 3.2GHz i7 32GB RAM
Slate, Waves, Soundtoys, GRM Tools, Audio Ease etc etc..
Re: Zoom To Track?
It's a command. View > Zoom > Zoom to Track. alt-cmd-z
Re: Zoom To Track?
taka wrote:I have "View Selection in Sequence Editor" assigned to one of my Wacom tablet pen buttons (my main pointing device), which does the same thing as you describe, I think... It opens whatever is selected (in any window) in Sequence Editor at the size of SE window.
Taka
Thanks for the suggestion. DP also crashes when I use this command.
Re: Zoom To Track?
I still can't duplicate this. Is it on all projects? On your MBP, too?
Re: Zoom To Track?
Yes, seems pretty general. Maybe it's specific to some graphics parameter. I'll try various screen sizes etc., and then see what tech links has to say. Thanks for testing.
Re: Zoom To Track?
bayswater wrote:...
Works fine here. ⌘ ^ (up arrow) works also.
Re: Zoom To Track?
mikehalloran wrote:
bayswater wrote:...
That's what I use most of the time. But I also use the other zoom commands to get to specific views with one keystroke. This one looked useful for that scenario, but in it's stead I'd use the zoom tool rather than ⌘ ^
