Motu M2/M4 Latency with Voicemeeter
Seren
Post by Seren »
Hi,
I've been experimenting with Voicemeeter Potato and I was wondering if something could be done to reduce the latency any further. On the output side of things, 64 samples seems to be stable as a buffer for the playback DAC as shown in the picture below (ignore the Voicmeeter ASIO setting at 128 samples, it can't go any lower). It is unstable at 16, but any value between 16 and 128, I perceive as the same roundtrip latency through Voicemeeter (compared to the interface monitoring button).
However, the input buffer using WDM is fixed at 528 samples and I don't know how much that is causing the perceived latency. I'm wondering if that can be improved in any way. I can't see an ASIO device for the input (Voicemeeter isn't seeing it, but I believe Ableton is, unless I misunderstand what WDM means).
https://imgur.com/4tlLexv.jpg
