I was distracted by an SOS article about this product.
First, it says it has 24 channels, 4 analog, and some ADAT, but only one ADAT input. Has ADAT been updated to run more than 8 channels? Did it always?
Second, it reports latency in samples rather than milliseconds. The latency is something like 6 samples in and 5 samples out, or something along those lines. At 48K that's a lot less than 1ms -- something like 0.2 ms round trip. You'll get more latency playing an upright piano or a snare drum. But where do you get a DAW that will set a 12 bit buffer?
Third, it uses USB 2.0. MOTU has been criticized here and other places for sticking with USB 2 for the M2/4, but it looks like there's a lot of life left in that protocol.
New Babyface Pro FS
New Babyface Pro FS
Re: New Babyface Pro FS
Here are the complete specs.
https://rme-audio.com/babyface-pro-fs.html
As mentioned in the M2 thread, lots of new USB 2 interfaces hitting the ground beginning late September. This adds ADAT giving 8 more channels in addition to the 2 mic pres and stereo line = 12.
6 samples less latency on the AD side by new ADC (5 samples AD, 7 samples DA. It won't get quicker...). Yea, that's weird but I'm expecting it will be the same 2.7 ms round trip of all the other recent USB 2 interfaces with Loopback/Blend that are Class Compliant as this one also claims to be. The control is called TotalMix here and there are switches to determine what you are totally mixing, I suppose.
As for ADAT, nothing's changed.
DIGITAL INPUTS
ADAT Optical
1 x TOSLINK
Standard: 8 channels 24 bit, up to 48 kHz
Double Speed (S/MUX): 4 channels 24 bit 96 kHz
Quad Speed (S/MUX4) : 2 channels 24 bit 192 kHz
Nice meters like the M4, a bit more flexibility if you have an ADAT converter like an old 828mkII or 2408 in stand alone mode. Might be something to consider, actually.
DIGITAL INPUTS
ADAT Optical
1 x TOSLINK
Yes, it looks great and if the history of RME is anything to go by, this one will last a long time. But pretty expensive, and I don't use a lot of channels very often anymore. I can cough up 40 channels of ADAT A/D with old interfaces laying around if necessary. I'm still waiting for the MOTU M4 to show up locally.mikehalloran wrote:Nice meters like the M4, a bit more flexibility if you have an ADAT converter like an old 828mkII or 2408 in stand alone mode. Might be something to consider, actually.
